Is that in reply to me?Think there's a guy on 'an' a/v forum that started a gen8 thread and set up esxi no probs.
But after spending the last 2 weeks with it, I'll never go back to either of those from my current solution: Plex on the N54L, a Chromecast into the TV, and a phone/tablet as the remote and to choose what to play next. It's neat, it's simple and it really works very, very well. I find it to be far less fiddly and would recommend it to anyone over a HTPC now. I'm a total convert.
On my gen8 I can't seem to access iLO using NIC1, only when specifically plugging the ethernet into the dedicated iLO port. How do I change it so I can use network/iLO both through NIC1?
Also, I've plugged a SATA HDD into bay three but it doesn't get recognised. Drive is definitely working as tested in USB caddy on my laptop. SSD in bay one works fine. Do I need to "register" it somewhere in the BIOS or iLO?
Who makes the NICs on the gen8? I was trying to find out but struggling, I'm hoping they're intel...
Sorry, only just seen this as we must have posted at the same time.It should just work. The only thing that springs to mind is that port 3&4 are SATAII rather than SATAIII. What hard disk is it, does it have jumpers to enable SATAII mode?
Why is it so hard to find the power cable for the Gen8's for the top bay in the UK
