- 22 Apr 2014
Here is a new range of SSD from Crucial with 4 different drive sizes for all your needs. From the Entry level 120GB through the 250GB and 500GB tio the big daddy 1TB drive. Plenty of speed to go with that size as well. These are aimed at the consumer and don't have the speeds of the MX100 or M550 range. These are replacing the MX100 as entry level units. The M500 and M550 ranges will be going to be replaced later.
Crucial BX100 120GB SSD SATA 6Gbps 7mm Solid State Drive (CT120BX100SSD1) @ £58.99 inc VAT
Boot up almost instantly. Load programs in seconds. And accelerate demanding applications with ease. It all starts with ditching your hard drive.
The storage revolution that started in 2008 with our first SSD continues with the new Crucial® BX100. Engineered to outperform a hard drive and deliver cost-effective performance, the Crucial BX100 leverages advanced flash memory technology and moves your computer beyond the outdated storage limitations of spinning discs. By transmitting data in a digital manner rather than having to seek it out on a spinning platter, the Crucial BX100 makes nearly everything on your computer faster and more efficient.
Over 15x faster than a typical hard drive
Get more done in less time – or just have more fun. The Crucial BX100 SSD is over 15 times faster than a typical hard drive and delivers true 535 MB/s sequential reads on both compressible and incompressible data. By treating all data the same, the Crucial BX100 allows you to do everything quickly, regardless of whether you’re saving an image, accessing a ZIP file, or loading a video.
Over 2x more reliable than a typical hard drive
Protect your data by storing it on the Crucial BX100, which is significantly more reliable than a typical hard drive. In the computer industry, storage drive reliability is measured in mean times between failures (MTBF). Most hard drives have MTBF ratings of 0.6 million hours, whereas the Crucial BX100 has a reliability rating of 1.5 million hours. In practical terms, the more reliable your drive is, the less likely it is to crash.
Nearly 2x more energy efficient than a typical hard driveRun your system longer and harder – using less power. With Extreme Energy Efficiency technology, the Crucial BX100 is over 90% more energy efficient than a typical hard drive. Since SSDs access data digitally rather than seeking it out on a spinning platter, they consume significantly less power.
Better value than a typical SSD
Get more out of your system – without compromising quality. At speeds up to 535 MB/s, the Crucial BX100 SSD isn’t the fastest drive on the market, but that’s squarely our intent. We painstakingly engineered the Crucial BX100 to provide a massive performance boost, while also delivering an unrivalled value among SSDs. Make the switch to the Crucial BX100 and get everything you expect from a Crucial SSD at an unexpected value.
Specifications:
Only £58.99 inc VAT.
ORDER NOW
Crucial BX100 250GB SSD SATA 6Gbps 7mm Solid State Drive (CT250BX100SSD1) @ £92.99 inc VAT
Specifications:
Only £92.99 inc VAT.
ORDER NOW
Crucial BX100 500GB SSD SATA 6Gbps 7mm Solid State Drive (CT500BX100SSD1) @ £169.99 inc VAT
Specifications:
Only £169.99 inc VAT.
ORDER NOW
Crucial BX100 1.0TB SSD SATA 6Gbps 7mm Solid State Drive (CT1000BX100SSD1) @ £339.98 inc VAT
Specifications:
Only £339.98 inc VAT.
ORDER NOW
Specifications:
- Sequential Read MB/s: 535
- Sequential Write MB/s: 185
- Random Read IOPS: 87k
- Random Write IOPS: 43k
ORDER NOW
Specifications:
- Sequential Write MB/s: 370
- Random Write IOPS: 70k
ORDER NOW
Specifications:
- Sequential Write MB/s: 450
- Random Read IOPS: 90k
ORDER NOW
Specifications:
ORDER NOW
