Corsair Air 240 & Grx cards?
30 Nov 2013
UK
Can anyone tell me if the Palit GeForce GTX 970 JetStream fits in the Corsair Air 240 case? I've read reviews saying some cards (specifically MSI's 970) do not fit in the case.
Cheers.
I'm not 100% sure but I think you're restricted in height, cards that go any more than about 10mm over the PCIe bracket size won't fit.
Check this out:
If you referring to the length, that Jetstream card should fit fine. We say its up to 290mm of length, but I have seen ppl fit up to 308mm. Length is not an issue. Width however is a little tricky due to different GPU cooler designs, but I'd use this photo as a reference to get some of kind of idea on how much clearance you have for that card.
http://www.vortez.net/index.php?ct=articles&action=file&id=27534
Palit's site spec's width at 126mm, so looking at that pic it should fit. If anyone has one in this case let me know, thanks.
Ive had an msi 780 twin frozr in mine, I very tall card and took some research to find if it would fit, it did but I slightly scuffed the paint on the extended fan shroud ont he top of the card. I think the msi is one of the tallest too.
Someone asked about that card on another forum and he said that his didn't fit. Do you mind posting a photo? just want to see how much it extends to the case' side panel.
Ah I see, I guess you really have play around with it when installing to seat the card properly. I'll keep that in mind. It's just there too many non-reference cards nowadays I tend to lose track of which cards fits and the ones that don't,
