Permabanned
- 9 Jun 2009
- London, McLaren or Radical
I have Raid5 on my Gen8 got a second hand P410 (1GB with Battery) from the bay for £45, very solid and does the job great, there are loads of them around as well so finding one should be really easy. It also means I can run my SSD from the second SAS port on the raid controller.
Good bargain, I'll keep my eye out for a similar deal... I've use the P410 for a lot of systems I've worked with.
Why have the OS on a separate drive to the RAID drives?
On a different RAID array as part of the same drives, sure.
Because there is a 5th SATA port on the motherboard and you might as well use it... because you can muck around without risking the integrity of your data.
Because it minimises data access times, drive access times, etc, all reducing load and elongating the life of the drives involved...
