Corrosion with Nickel and Copper/Brass
29 Dec 2014
The "North"
Hi, I'm just looking for clarification that my water cooling parts are safe to use. I understand that you shouldn't use aluminium with copper as it is too reactive but Nickel, Brass & Copper are close on the reactivity series so they should be safe to use together but I'm not sure so any help is greatly appreciated.
YOUR BASKET
1 x EK Water Blocks EK-Supremacy EVO - Acetal £49.99
1 x XSPC EX240 120mm Radiator - Black £34.99
1 x PrimoChill Revolver Compression Fitting Acrylic Tubes 13/10mm Diamond 4-pack - White £19.99
Total : £114.58 (includes shipping : £8.00 Ex.VAT).
You should be using corrosion inhibitor in your loop regardless to stop corrosion even between nickel and copper. Most pre-mixes come with it already in there, if you're making your own you should be adding it as an additive.
X1 None glycol
XT1 glycol
Pastel None glycol
Aurora None glycol
Pastel Extreme - contains trace amounts of glycol
after further extensive testing
XSPC is glycol based
CF (poisonous) glycol based
Primochill glycol based
X1 None glycol
XT1 glycol
Pastel None glycol
Aurora None glycol
Thanks for summing it up clearly. I'll be using Mayhems X1 then :D:D
Also just checking, although Mayhems has an anti-corrosive does it contain a biocide?
