Just drive the damn thing, if your clutch starts slipping.. you need a new one, if it doesn't, you don't need one!
400 is a lot of money to throw at something that may never actually fail in the time you own the car
Its not really a rattle, when you decelerate in gear there is a "shhhhhhhhhh" sound which changes pitch depending on the engine speed, rather than the gear speed, and it does it in neutral too if you hold it at the right RPM. When you depress the clutch, it goes away.
You are somehow linking a worn clutch release bearing, to an oil change, to an engine going bang..?
I'm gonna get it done though I think. I can't think of anything I'd rather spend £400 on than improving the car.![]()
No the release bearing went inside the box in my ATR. You could still change gears although it could be heard rattling inside the box. Damaged the box so do keep an eye on it. Oil change did not help quiet it down. Engine was fine lol.
