Best way to clean/dust off pc case
I never clean my PC... When it gets dusty I just order new components and build another (Joking of course :D).
I just use a PCB brush and a can of compressed air. I never thought about using a small air bed pump. I have a Regatta inflator/deflator, but it doesn't seem that powerful.
You might be joking but that's exactly what I have done. I was careless with my PC for the first few years of owning it and it's so dusty/dirty inside I decided to just get another case.
I'm wondering how I can easily clean a whole case with 0 components in it, friend suggested using a water hose but I can't imagine that working out too well... And as people have already mentioned, canned air just doesn't cut it.
Jokes aside..IM BATMAN
If you do use a can of compressed air, a top tip is to have a large fan blowing gently across the case to blow away the dust that's been blown out.
Manual air pump with both pc case sides removed, just inside open front door, in case it starts raining.;)
Buy an inflatable bed pump they work well enough with a narrow nozzle been using one for years.
compressed air cans are a ripoff I'd buy them if they were 10p each I guess.
