sadly only for 2 fans, and not for push pull]
push pull is a total waste of time.
Jays 2 pennies worth has had his full review up all day, of the 240mm the results are pretty sweet, there is one little problem with the mounting though, but only on Asrock, and Gigabyte 2011 motherboards. I won't spoil it for you all though.
It is rather sexy looking and it has a nice little PWM pump and fan board, sadly only for 2 fans, and not for push pull, unless there is enough head room for a a 2 way splitter on each fan connector.
It may have been asked and answered but,
Does this fit up top in a Air 540?
Hi All, will the 360 version fit in the top of a HAF 932 Advanced?
Having watched that, surely it would have been easier to grab a hack saw and trim the 115X part of the bolt than risk drilling a motherboard.
There may be no traces on the surface but there may be some inside you cant see.
You should not need to start cutting up the screws surely EK can supply long and short screws?
EK support recommended EK-Supremacy EVO*PreciseMount*kit for people with incompatible motherboards although EK say that it's only gigabyte and asrock my Asus x99 deluxe doesn't have the mount holes going right through so I could always drill them out lolThat too but I was referring to Jay's broken logic in his video.
What would you risk wrecking:
4x 1 cent clips
4x 10 cent screws
1x $150 motherboard
O wait....
The alternative is to go AIO, fancying the Predator 240mm just wondering how quiet they are - I've seen performance benchmarks but not noticed anything about noise yet.Hi guys,long time lurker first time posting.I was hoping you might be able to help me.I preordered the 240 Predator, thing is I have a fractal define R5 bo edition and I am thinking that I may not be able to clear the ram, if I mount it in the roof.I am using http://www.corsair.com/en/vengeance-8gb-dual-channel-ddr3-memory-kit-cmz8gx3m2a1600c9b .I am thinking I may have to buy some low profile ram?
