** GTX 980 DEAL TO END ALL OTHER 980's!! **
OcUK Staff
17 Oct 2002
OcUK HQ
HI there
This is a truly incredible deal, infact it is completely bonkers as this is one of the best and fastest GTX 980's on the market, plus it looks absolutely awesome as well in its all black aesthetics and performance is absolutely mind blowing. Considerably faster than any GTX 970 and not much slower than a reference 980Ti, making its price point absolute spot on at £100 more on average than a 970 and over £100 cheaper than a reference 980Ti and around £150-£200 cheaper than custom 980Ti's. :)
KFA2 GeForce GTX 980 "8Pack Edition" 4096MB GDDR5 PCI-Express Graphics Card @ £389.99 inc VAT
8 Pack branches out further now with his very own graphics card. Aesthetically this is a great looking card with black PCB, Black/Gunmetal cooler, black fans and a black 8 Pack backplate. Enough about the looks this card has a further revised PWM/VRM compared to the original HOF cards. That means even great overclocking potential resulting on average far higher overclocks being made reachable like 1500MHz+ and region of 8000MHz memory clocks (not guaranteed).
With so much performance on tap out the box, infact this card out the box out performs any other 980 on the market and gets very close to Titan X performance, this card is an absolute beast.
Remember the perfect companion for the 8 Pack graphics card is of course the worlds most powerful and stable 8 Pack 2000W power supply built by Superflower.
Key Features:
- Completely redesigned PCB layout from the ground up, optimized for GM204
- 10 layer manufacturing process in 8 Pack signature black/gunmetal cooler
- Extended PCB width for optimized layout and cleaner signal
- Advanced GALAX exclusive "Triple Force" cooler
- 2x 80mm fan + 1x 90mm fan
- 4x 8mm heat pipes + 3x 6mm heat pipes (total 7 nickel-plated heat pipes)
- Copper base cooler
- Integrated MOSFET heatsink
- Customizable top HOF LED (control blanking frequency, brightness with GFE)
- Plastic cover with premium die-cast aluminum accents
- Anodized aluminum backplate protects components and reinforces PCB
- Next generation IR3595 Digital PWM controller provides 2X switching frequency vs. previous generation
- 8 phase GPU + 2 phase memory power
- IR3555 with next gen DrMOS and 60A output
- Aerospace-grade GALAX Extreme Power Inductors provide ultra-long life, high endurance and low noise vs. normal power inductors
- Hyper Boost technology acts like a hardware turbocharger, increasing fan speed and maximum power delivered to the GPU with the push of a button
- Hardware dual BIOS simplifies the tweaking process by enabling risk-free firmware updates and customization
- Prelim internal overclocking results: >1.5-1.6GHz on air, 1.55-1.65GHz H20, 2.1-2.2GHz on LN2
Specification:-
- Multi-layer ceramic capacitors
- GeForce GTX 980
- GPU: GeForce GTX 980 (GM204)
- Process: 28nm
- Core Base Clock: 1304MHz
- Core Boost Clock: 1418MHz (1440-1480MHz effective hyper-boost clock)
- Memory Clock: 7010MHz
- Memory Size: 4096MB GDDR5
- Bus Type: PCI Express 3.0
- Memory Bus: 256-bit
- CUDA Cores: 2048
- DirectX 12: Yes
- DVI Port: 1x Dual-Link DVI, 3x DisplayPort & 1x HDMI
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power: 2x 8-Pin
- 750W Premium PSU Required
- 180-500W TDP
- Dimensions(with Bracket): 308*129.1*49mm
- Dimensions(without Bracket): 294*116*46.1mm
- Review: http://www.kitguru.net/components/graphic-cards/zardon/kfa2-geforce-gtx-980-8pack-edition-4096mb/
- Warranty: 3yr
Was [£429.95] Inc. VAT
Only £389.99 inc VAT.
ORDER NOW
CHECK OUR NVIDIA GRAPHICS RANGE!!
16 Jan 2008
East Sussex
But from a value for money point of view now the game has gone the price hasn't really changed as its lost a game that's what £45 on steam? so unless you've got a few copies left to throw in not really much of a deal from a value for money side of things.
OcUK Staff
OP
17 Oct 2002
OcUK HQ
Its not about us having copies left, it is a NVIDIA promotion, so the fact I have a few hundred here is irrelevant, NVIDIA have ended the promotion and what they say is final.
