Show Us Your Motors!
15 Aug 2005
Glasgow
a few more, didn't have the chance to take any better pics !
do like the car tho! going to send it for a 360 service soon just for the piece of mind to get everything checked over, fluids/filters changed and belts checked!
Looks very nice, quite like the wheels too and I'm not usually fan of them that dark.
Does yours have the AUX input as standard? Fairly(ish) straightforward to add if not, did it on mine and although it was a daunting task once you've taken all the trim off and the stereo out, it went okay and works well.
Also recommend changing the crap interior bulbs to LEDs, makes such a difference to how the interior feels, plus you can see what you're doing. I changed my sidelights to LED at the same time so they match the white Xenons.
Do you know about being able to open/close all the windows from the remote?
12 Mar 2008
West sussex
no it did not have the aux input, it's early 2007(jan).
I did add the aux input cable but the audio quality compared to CD is ridiculously bad! might be the cable though, which cable did you buy? I got this -;
http://www.amazon.co.uk/PBELE-3-5mm...UTF8&qid=1447261857&sr=8-1&keywords=mazda+aux
and while it works, the bass is low, the audio is just "empty/cold" there's no warmth tho it at all.
I was thinking about it! interior LED's are a bit too dim for my liking, was it hard to do? what type of LED's do you need for the interior?
yeah, learned that by accident haha, was walking away from the car and pressed something on the keyfob only to see all windows go down! :o
15 Aug 2005
Glasgow
Aux cable I used was this one:
http://www.amazon.co.uk/gp/product/B006FFCONA?psc=1&redirect=true&ref_=oh_aui_detailpage_o09_s00
Can't imagine there'd be a huge difference though? Might be your player, depending on what you're using. I've certainly noticed no real issues with mine.
I used two of these for the two front interior lights:
http://www.ebay.co.uk/itm/2-x-6-SMD...UPER-BRIGHT-/370867129035?hash=item5659674acb
And one of these for the rear centre light:
http://www.dx.com/p/festoon-31mm-3w...g-car-reading-lamp-dome-bulb-12v-2-pcs-235820
Makes the car feel a lot more modern and fresh inside, I'm really happy with them. You can use the second Festoon bulb in the boot too, if you bend the metal clip that holds the bulb a bit.
My sidelights are these ones:
http://www.ebay.co.uk/itm/x4-ERROR-...-PURE-White-/321654205961?hash=item4ae415ae09
But they feel really loose inside the bulb connector so I'm looking at alternatives that won't be knocked loose and end up rattling around inside the headlight housing. :o
5 Jun 2004
Yorkshire
Love the photography work on the Supra
cheers, my first attempt at light painting :)
Here is another from the same night with some friends, fog was really bad but adds some atmosphere :)
12 Mar 2008
West sussex
awesome! thanks.
eh, I don't think its my unit tbh! I will be getting this -;
http://www.eonon.com/Car-GPS/Android-Car-GPS/Mazda/GA5151F.html
very soon! :) but for now I wanted aux in.. will try the cable you bought :o :)
thanks for the LED link! got a set for my interior, current ones are really dim.
I don't ever use my sidelights.. it's either they're on dipped or off, not sure if it's worth upgrading, are leds much brighter?
15 Aug 2005
Glasgow
I never use my sidelights on their own either, it was more just so when they're on alongside the Xenon headlights they're the same colour (white) rather than the ugly yellow-ish of the regular bulbs.
26 Sep 2006
West Bridgford
Thanks, there was a lot of searching through 2 litre diesels...
It was an ex BMW UK car. Spec below:
BMW 435i Gran Coupe
‘64 plate – 1,036 miles
Sports Auto transmission
Sunroof
Professional Navigation
Heated Steering Wheel
TV Function
Harmon Kardon Speaker System
M Sport Plus Pack
Extended Storage
Adaptive LED Headlights with high beam assist
Heads Up Display
Folding Mirrors
Front Armrest
18 Oct 2002
Wolverhampton
Nice spec :)
Last time I visited my Uncle he'd just got his new BMW, petrol BMW 6 grand coupe...a 640i M Sport in melbourne red. There are still some purists out there when it comes to engines, he was reluctant enough to consider something with a turbo (the 640i is a turbo 6, introduced with the facelift of the 6 series I think, unless it was 635i before?).
