- 14 Oct 2007
- newcastle
It's the satnav.
Seems pretty self-explanatory?Screen says said:The DVD insert shutter is open on the front of the Navigation unit.
Please close it to continue.
Then he doesn't have the navigation CD/DVD and/or remote control and is fobbing you off.
I promise you, it's the satnav.
By buying another S40 from a reputable dealer.
Did you actually look at the navigation unit to close the shutter? The remote could well be in the glovebox.
What a great place - the car salesman doesn't know anything about cars!Yeah the guy that said it wasn't a satnav was just the salesman the guy that deals with the cars knew right away it was a nav unit and when I had rung up this morning had already ordered a remote and new disk
Not suggesting it should be a deal-breaker if everything else fits the bill and there are few local alternatives available, but that would worry me a bit in terms of whether it is the sort of firm I'd want to be doing business with. In other words, can you be sure any prep work has / will be done to a suitable standard, what happens if you have any problems are you going to have to be dealing with imbeciles, is everything they have told you about the car spec factually correct etc etc. When this fella told you it had a full size spare wheel, you thought he meant one under the boot, whereas he was thinking the one shown in the picture...![]()
Ooooh does it have the D5? I love me a D5.![]()
