Caporegime
M&p,busters,demon tweaks,eBay,they are all good depends what you need
[Using petrol] Won't hurt it
Wrong.
If it's a 125 it'll probably have an inner tube with can be patched
Yup, submerge is a completely different story. It's like that teeth in coke experiment, where they leave a tooth in there for 24 hours and it goes black. That doesn't mean it's going to damage your teeth as 1. you don't do it that often and 2. it's just passing contact.
Granted you're probably not going to wash all the petrol or whatever you use off (if it doesn't evaporate anyway), but there won't be enough surrounding it for long enough to cause issues.
First test ride since finding that spring all twisted in the diaphragm and service.
Only gone and fixed it !!!
Went around town for 10 minutes to warm everything up then went to a nice long stretch of road and opened the tap IT'S BACK !
Blooding freezing though and the roads look nasty with grit. All pressure washed to get rid of muck and back in the garage.
Bring on the summer !! oh wait I live in Glasgow
Petrol evaporates though with seconds
