Sprocket carrier bearing for CBR600 F3
4 May 2009
Southampton
Hopefully there are one or two that know the answer to this.
As I'm replacing the cush drive rubbers and I figured I'd replace the sprocket carrier bearing at the same time. However I don't know if I need one set of bearings or two (like one for each side).
Does anyone know? Google has not been forth coming on this one
31 Oct 2006
Wiltshire / Winchester
It was more for the sake of a few quid I might as well do it while the wheel is off and save me coming back to it at a later date
I would definitely recommend you doing it, mine was fine when I changed a tyre last year, no problems in the MOT then two weeks later I change my back tyre and the bearing is knackered, make sure you get one thats sealed, will probably outlast the bike then :p
OP
4 May 2009
Southampton
Yeah I picked up a 'double sealed' bearing. Hopefully will be here today with the rest of the parts for her.
Parts:
exhaust gaskets
very high temp paint
head studs and bolts
rear brake disk
rear brake pads
cush drive rubbers
chain and sprockets
