- 9 Jun 2011
i5 and 780 should have stuck with it, hard with 800 budget wait for pascal
Perhaps a bit desperate but you could always save some cash by going with a 6 core AMD piledriver processor. Yes, it's older tech with slower DDR3 memory but with the money saved you might be able to go up to an R9 390X or GTX980 for even the XFX Fury is £359 from OCuk at the minute. If DX12 delivers as is promised going forward, those 6 cores could actually give you advantage over the 4 core i5's if it's just for gaming... bit of a gamble I suppose.
Probably best to wait although that would much easier said than done for me...
Worst advice ever, even amd 8 cores struggle against old i5's let alone skylake,
Op congratulations on becoming a father I would wait or go used
I'm shocked to find out that after 3/4 years I can't improve on old rig for similar ££££.
How do I add photos? I got the PC for £820.
