Forza 6 (Apex) coming to PC near you, soon....
26 Sep 2013
West End, Southampton
Hmmm well thats weird.
Heres something else thats really strange. When Im racing, if I move my mouse from the bottom of the screen so the task bar hides, my fps feels like its about 30. When I move the mouse pointer to the bottom of the screen so the task bar shows, my fps feels like it locked at 60, it's a totally different experience. It's so weird, all im doing is showing the task bar and hiding it and the different in fps is double.
7 Aug 2013
It felt like i couldnt turn worth a damn at any speed tho like the wheel wasnt turning all the way around just a bit left or a bit right.
This sounds like something is not working properly with your input device rather than it being something to do with the handling model.
Speaking of which, the game seems to support rumble triggers with the XB1 pad. But I'm curious if it still supports rumble(of any kind) with the 360 controller. Anybody try it out yet?
24 Oct 2005
North East
Im just using wasd on my logitech g110
24 Oct 2005
North East
In windows store under forza it says I need to upgrade windows aka.ms/winup
I'm on w10
Theres a few different versions of windows 10 about apparently. If you got a error and it provides a link its probably wants you to upgrade to the latest windows 10 platform version. 15xx or somit
If you go to start button (im using classic shell) then pc settings then system then about, it should tell u which version ur on, mine is 1511 for example and forza installed fine on it.
7 Aug 2013
Ah ok. Ignoring that it's an absolutely terrible way to play a racing sim, I really wouldn't be surprised if that's what is causing the issue as it's not a typically well-supported input scheme. And it would also be one that Turn 10 have never implemented before. Forza games also use a sort of steering assist to smooth out left/right steering inputs, which is useful for people using analog sticks as it's hard to finely modulate steering using such a small window of operation. So this might not be playing well with on/off steering inputs like you have using keys.
So does this support thrustmaster t150?
Wheel support is coming later.
8 Oct 2015
Hastings
19 Apr 2006
I have the same issue but my one only says Windows 10 Pro. Running the Windows download anyway to see if this upgrade works anyway.
8 Dec 2005
Good effort from MS + Turn 10. Looks pretty good @ 4K. Needs a monster PC for max details though I can only run it in High @4K. GTX 980 Ti 6Gb VRam is not enough for max apparently!! As expected only needs 6Gb System Ram to run as long as you have a 6Gb VRam GPU.
Reminds me a lot of Project Gotham 3 + 4 from the Xbox360 days :D
25 May 2013
Kent.
Guy on reddit is running this on a GTX 580, but my card won't? I don't understand. Didn't think a 580 had the DX12 support needed, it's not that far ahead of my card.
@Above, Fraps?
19 May 2005
Lancashire
CTD on my second race, but it does look and run pretty well so far. I much prefer Gran Turismo though. Unless its just this cut down version, but there doesen't seem to be much freedom to choose what races you do and tune the cars etc. Not impressed so far.
26 Sep 2013
took a few with my camera until i figure out a program that works with the game...think its going to be a problem as the game runs in window mode and DX12. Will get some race shots in a bit
I'm in car heaven
