- 30 Sep 2005
This is a tip toe for MS into the world of PC gaming via the store
Theres a few different versions of windows 10 about apparently. If you got a error and it provides a link its probably wants you to upgrade to the latest windows 10 platform version. 15xx or somit
If you go to start button (im using classic shell) then pc settings then system then about, it should tell u which version ur on, mine is 1511 for example and forza installed fine on it.
You need windows 10 version 1511 to download on the store,for some reason windows update doesnt upgrade everyones windows 10 to 1511.
I had to download the latest version from microsoft and use the upgrade option,to fix windows.
Guide on this site http://www.groovypost.com/howto/ins...ber-update-1511-manually-media-creation-tool/
What's the button on the xbox controller to chage driving cams?
Is this a fully fledge forza 6 game thats same as xbone version?
No. Not even close.
You need 16Gb System Ram + 6GB Vram for UltraAny one know why I can't run Ultra? Surely the spec in my sig is enough for ultra 1080p definitely didn't have any issues running high.
