**BEQUIET ALL IN ONE COOLER HAS LANDED**
Gangster
OcUK Staff
16 Mar 2008
OcUK HQ
Hi,
The much anticipated All in one cooler has finally hit the market. We have seen and heard many things about these coolers for a few months and now we have them in stock.
These silent coolers use new technology compared to the rest of the market. Bequiet did not want to just release another AIO cooler they wanted to be different and make something no one else has. In the quest to get a silent cooler they have designed a cooler that uses a reverse flow pump which allows it to run smoother, have less vibration and most important silence.
The coolers will come in sizes of 120mm, 240mm and 280mm.
Cooler Details:
Superior Cooling and Silence
Silent Loop brings the famous be quiet! whisper-silent technology to the world of All-in-One water cooling. Designed to make installation simple, Silent Loop includes everything needed in one package.
Highlights:
- Innovative decoupled reverse-flow pump runs smoother, quieter and with less vibration than conventional pumps
- Full copper radiator for an impressive cooling performance
- Two Pure Wings 2 PWM fans provide quiet operation with high air pressure
- Customized fan speed thanks to PWM function
- Easy handling due to flexible bend-protection tubes and convenient mounting
- Full copper parts and a refill port extend the product’s life span
- Nickel-plated cold plate allows optimum use of heat-conducting metallic paste
- Compatible with Intel® and AMD™ sockets
- 3-year manufacturer’s warranty
- Product conception, design and quality control in Germany
Ideal Applications
- Demanding PC Systems
- Overclocked CPUs
- High Resolution Gaming and Multimedia PCs
- Superior Quiet HTPCs
Silent Loop
No compromise is required when choosing to water-cool demanding systems and overclocked CPUs.
The decoupled reverse-flow pump runs smoother and with less vibration than conventional pumps. Thanks to the
innovative technique “reverse-flow” the pump draws in the liquid coolant from an outer cavity of the pump housing across the base plate and discharges the warmed liquid coolant through a second level inside. This is the key to guarantee the well-known silent be quiet! operation.
be quiet! Silent Loop Superior Liquid CPU Cooler - 120mm @ £94.99 inc VAT https://www.overclockers.co.uk/be-quiet-Silent-Loop-Superior-Liquid-CPU-Cooler-120mm-HS-014-BQ.html
Socket compatibility: Intel®: LGA 775 / 1150 / 1151 / 1155 / 1156 / 1366 / 2011(-3) Square ILM, AMD: AM2(+) / AM3(+) / FM1 / FM2(+), 3 Year Warranty
Technical Data:
- Model: 120mm
- Dimensions radiator, incl. fan (H x W x D), (mm): 153 x 128 x 95
- Maximum power capacity (W TDP): 270
- Pump Type: Reverse Flow Pump
- Pump Speed: 2,200
- Pump Connector: 3 Pin
Radiator Specification
- Dimensions: 153 x 128 x 45
- Radiator Material / Finish: copper / black spray painted
- Base Material / Finish: copper / dark nickel plated
Fan Dimensions
- Fan dimensions (mm) / Quantity (pcs.): 120 x 120 x 25 / 2
- Noise level (dB(A)) @ 25 % / 50% /100% rpm: 16.1 / 23.8 / 36.9
- Speed @ 100% PWM (rpm) : 2,000
- Airflow @ 12V (cfm / m3/h): 65.51 / 111.3
- Air pressure @ 12V (mm / H2O): 2.23
- Bearing type: Rifle
- Motor technology: 4-pole fan motor
- Connector: 4-pin PWM
- Lifespan (h / 25°C): 80,000
Only £94.99 inc VAT.
ORDER NOW
be quiet! Silent Loop Superior Liquid CPU Cooler - 240mm @ £114.95 inc VAT https://www.overclockers.co.uk/be-quiet-Silent-Loop-Superior-Liquid-CPU-Cooler-240mm-HS-015-BQ.html
Technical Data:
- Model: 240mm
- Dimensions radiator, incl. fan (H x W x D), (mm): 277 x 124 x 55
- Maximum power capacity (W TDP): 350
- Pump Speed: 2,200
- Dimensions: 277 x 124 x 30
Fan Dimensions
Only £114.95 inc VAT.
ORDER NOW
be quiet! Silent Loop Superior Liquid CPU Cooler - 280mm @ £129.95 inc VAT https://www.overclockers.co.uk/be-quiet-Slient-Loop-Superior-Liquid-CPU-Cooler-280mm-HS-016-BQ.html
Technical Data:
- Model: 280mm
- Dimensions radiator, incl. fan (H x W x D), (mm): 319 x 144 x 55
- Maximum power capacity (W TDP): 400
- Pump Speed: 2,200
- Dimensions: 319 x 144 x 30
Fan Dimensions
- Fan dimensions (mm) / Quantity (pcs.): 140 x 140 x 25 / 2
- Noise level (dB(A)) @ 25 % / 50% /100% rpm: 16.1 / 24.1 / 37.3
- Speed @ 100% PWM (rpm) : 1,600
- Airflow @ 12V (cfm / m3/h): 94.2 / 160
- Air pressure @ 12V (mm / H2O): 1.82
Only £129.95 inc VAT.
ORDER NOW
1 Mar 2010
5 degrees starboard
I like the copper radiator, the thought gone into reducing pump vibration, (see if that works well or not). Full PWM capability. 3 year warranty.
Needs conformation of AM4 (Zen) fitment for me to consider it. Would go for the 280 of any of them.
Gangster
OcUK Staff
OP
16 Mar 2008
OcUK HQ
£95 for a 120mm AIO? Wat.
Same price as the successful H80i.
I will look into this for you. I would imagine a bracket will be released maybe at a later date.
I'm intrigued by the 240mm variant... would need to see some reviews, how does it compare to the Corsair H100i V2/H105?
Hi, Reviews will be available this week.
Gangster
OcUK Staff
OP
16 Mar 2008
OcUK HQ
Is there something special about them, or are they essentially the same as all the other 120/240/280MM AIO's, aside from the higher price tag?
These coolers use a different way of using the pump meaning it gets rid of that humming noise that most people comment about when trying to get that silent loop. These also come with some of the quietest fans on the market.
These prices are in line with other high end AIO coolers and these will be quieter.
Reviews will be on Kitguru within the next couple of days.
12 Jan 2014
What a miserable man, and a short review to boot :(
This is a significantly better cooler than the review suggests. The guy has no idea how TDP is handled, and if he doesn't think a 6950x can output 400 W I got words for him.
Gangster
OcUK Staff
OP
16 Mar 2008
OcUK HQ
We have just had our sample units and these coolers are so quiet. We have the CPU running at 4.7Ghz at 1.3v and stressing it with Intel Extreme Utility. Under full load and the CPU temps have gone no higher than 58c.
We are using the 280 version.
How quiet this cooler runs under PWM control is worth it alone and the performance is up there with the best AIO coolers.
22 Mar 2014
Thing is with AIO you can now get a decent custom loop for the same price as a good quality AIO. I know you can get some 240mm AIO for £60 but then you lose quality.
