Hello. So I just removed my battery to giv it a charge with my Carpoint 4 amp charger and I noticed that the 5 amp fuse that goes in the underside of the charger has blown. Could I use a 10 amp or 7.5 amp fuse instead? Thanks
No. You might as well just wrap the old fuse in tinfoil and bodge it properly.
If it's blown a 5amp fuse sticking something double the rating in there is going to put you at very real risk of needing to call the fire service.
At my work place they PAT tested all the electric items in my workshop and I had to dump everything that fail straight away or get it fixed before using again (He cut the leads or plugs off everything that failed)..
He then PAT tested the computers in the office and most them failed and there still using them a few months later..
