Caporegime
- 18 Sep 2009
- Dormanstown.
But SS was right about Zens IMC being naff (Although he explained himself terribly IMO), but I said the same at the time.
Don't understand the relevance when it says Zen can do DDR4-2666MHZ.
how does `naff` mean it can use 2666 ram? JADEC spec is 2133 which skylake uses
does that mean skylake IMC is also `naff`
Skylake does 3000Mhz guaranteed, I imagine Zen will do the same. Non issue really.
https://ark.intel.com/products/88195/Intel-Core-i7-6700K-Processor-8M-Cache-up-to-4_20-GHz
says the highest intel support is 2133 - that's the makers `guaranteed` speed
Bloomfield only supported 1066 MHz DDR3. Everyone used it with 1600 MHz DDR3. "Max supported" RAM specs are always bogus.![]()
2666(OC) for DRAM. That's likely as good as it gets.
Called it...![]()
Indeed. And that's why at the moment I wouldn't be drawing too much from the 2666 figure of a specific motherboard tech spec. Maybe it's the motherboard that is the issue?CPU vendors putting official support is a lot different than the motherboard manufactures putting OC speeds.
It's not the same motherboard though is it?Why would it be the motherboard that's the issue when they've got Intel MSI boards stating 3600+?
Until MB designers get used to the IMC on the CPU initial designs won't be the best possible.
I wish you'd stop saying JADEC.
