£2K budget, new gaming PC. Help me spec before 4pm cutoff?
There is one major issue, I still use a PS2 keyboard that I wont part with. (Dell clicky thing I love). Will need to get an adaptor.
That Asus board has a PS2 port at the rear (Top left).
One other thing that might be an issue though is the cooler. The R1 Ultimate is a big beast so it might block off the top pcie slot. I would ask the question first before ordering it.
A good alternative would be the Noctua D15S if you don't mind the Brown/Beige fan.
Oops, didnt see this.
Does the CPU come with a stock fan at least which I can then use if the R1 blocks the slot?
I did not expect the board to support PS2, awesome, thanks.
Mmmm, does the Win 10 media come on a DVD? Not bought a DVD drive although I should have spare and could probably just do a USB boot option, just need the product key afterall.
No you don't get a stock fan on X99 platform. If it does block off the top slot then you can always put the gpu in a lower slot. I am not 100% sure if it would run at full speed (x16) or at x8 but it shouldn't make any noticeable difference.
This link might help regarding W10.
https://www.microsoft.com/en-us/sof...402X558040Xa73e061213db2f861a53832822ffe012)()
Thanks, will manage then. If the cooler gets in the way Ill make a plan later if needed.
Thanks once again for everyone's help.
For Win 10, I just have it on a USB having downloaded ISO from MS site. There is a good free programme called Rufus which you can use to create a UEFI bootable USB drive. You only need a 4GB USB stick. You can then simply get a Win 10 key from any number of places, even see them on the MM forum here sometimes.
Thanks - about to try Rufus as Im loading Win 10 on an older laptop (need a serial port for some other stuff I do) and its struggling so Rufus was advised.
Key wise, trying to go legit where possible.
All up and running with the new machine. No real issues with the installation. I have a lot of 'unknown' items in the device manager, will apply the mobo drivers now and see how many it clears.
