Man of Honour
- 16 May 2005
- Manchester
Good stuff. Not sure I'd be bothered about "wasting" a bag in that case
However, I do think pan searing a steak gets better results than using a blow torch. Though I tend to do both - cast iron pan and Searzall.
Tbh with steak, unless it's a really decent thick cut of it, I'll often just do in a pan. It's easy enough to get very good results and less faff.
If I've planned my cooking better I'm more likely to use sous-vide. I'm all about the best results for the least active cooking time so there are definitely times sous-vide wins easily and others where it isn't quite so great. A good example is the cases where braising is often a better choice - lamb neck and ox cheek for instance.
