Raid 5, Yay or Nay..
Si.
Si.
22 Oct 2002
Melbourne, Aus
I'm currently running RAID-5 on my Synology NAS without any problems, I've been running RAID-5 on servers for 20 years and luckily never had a RAID failure (Other than those caused by human error). However I'm about to upgrade from my 4 bay NAS to an 8 Bay one and I'm starting to think I should now go to Raid-6.
What are peoples thoughts? I know Raid 6 will give me 2 disk redundancy, but is it worth the extra loss in space over adding in an additional RAID 5 disk? There are always worries about a corrupt RAID volume, and as drives get larger this risk increases, but if I'm currently running monthly RAID scrubbing on the array I'm hopefully mitigating this issue.
Any comments welcome.
19 Oct 2002
Auckland, New Zealand
I personally use SHR with 2 disc redundancy. Above four data drives on Raid 5 I tend to move towards Raid 6 to give me confidence that I can withstand two drive failures... raid reconstruction is quite intensive and with more drives, there is a hgiher chance of a drive failing during the rebuild. If you have fast internet (100mbs+) then you might be able to mitigate the drive loss from backup and get the array up quickly.
Don
19 May 2012
Spalding, Lincolnshire
What size drives and what is the NAS used for? What is your backup plan?
If it's data that is inconvenient but replaceable e.g. ripped blurays etc then by all means make use of the extra space in RAID5. Otherwise RAID6 is a better choice (and personally for anything super important RAID10 is even better due to less complexity and much faster rebuild times).
RAID Scrubbing is unlikely to be much benefit in RAID5, as all it is doing is comparing the data stripe to the parity data. If either is corrupt then all it knows is that one side is wrong, but which is side is correct? Not 100% sure on Synology's implementation but it is likely to just rebuild using the parity (even if that is corrupt). RAID6 should be slightly more reliable for scrubbing operations as you have 3 sources - (2 parity + data) so in theory it can look for 2 matching sources to correct the other.
Xez
Xez
24 Jun 2005
Lincolnshire
What size disks are you using?
Raid 5 is obviously brilliant for read speeds but like you say a raid failure whilst should be fine if you have large disks the rebuild time is terrible and during rebuild another disk can easily fail. Personally I would run raid 10 but a lot of disk usage is wasted.
Si.
Si.
OP
22 Oct 2002
Melbourne, Aus
Disks are 3tb.
Backups are ideal but I don't have the space anywhere.. None of the data is absolutely irreplaceable, but would be a royal pain to get back. Anything really important is also located on a local RAID 0 but that's nowhere near enough for everything.
12 Sep 2006
backup disks are more important than raid for most people - if its jut say a film library (or other data where 90%+ does not change from day to day), then not watching a few films for a few days whilst you recover is a safer.
if it's mission critical, then raid becomes more important. re raid 5 vs 6 - how long does it take to purchase & rebuild a disk, and are you happy for to risk a disk not failing during that time?
18 Oct 2002
SX, unfortunately
Disks are 3tb.
No way R5 then. R6 or preferably R10 if space/funds allow.
3 Oct 2007
The reasoning I've read around avoiding RAID5 with TB+ sized disks is not really around the risk of a further disk failing while you source a replacement. The biggest risk is the additional load you place all of the other disks in the array under during the rebuild - that is the time when your 2nd array-fatal disk failure is most likely to happen.
No RAID can be immune to this, but risk mitigation in a home setup can only go so far.
12 Sep 2006
had never thought of that, but then that's never happened to me. run some weirdly clever hp raid level at work, ADM i think it is.
i like raid 1 & backups at home though :) but then i'm not storing a stack load of data these days.
3 Oct 2007
Never happened to me either, I run RAID5 at home but I'm fully aware of the risks associated.
You'll probably find the SAN is using SAS rather than SATA drives which gives improved error correction and better advanced warning of failure.
The advanced warning then triggering the use of a hot spare (Or releveling in the case of ye olde HP EVA SANs) potentially before the data on the disk is unreadable.
9 Dec 2007
Hants
That's why you always have a backup :)
12 Sep 2006
ADM is Advanced Data Mirroring - nothing clever about it, just HP using their own name conventions for both RAID1 and RAID1+0 (and they call RAID6 "ADG" or Advanced Data Guarding)
It's not just RAID 1 though is it? RAID1 = 1 redundant disk. We have it set up to have 2 redundant disks, and before you shout that's just raid 6, it's set in a pool of three disks. Over cautious? Maybe, but i also know how long it can take a approvers & purchasing departments to get their wotsits in gear :( I also *think* it is clever enough to have improved read speeds as I seem to remember it reads 1/x of the data from each disk and combines them. Will check this though.
Hence me considering it clever compared to a normal raid setup.
Man of Honour
13 Nov 2009
Northampton
Regardless of the number of disks, if the data is mirrored across the array it is still RAID1.
