- 11 Sep 2013
Depends what aspect of the performance you're testing, I suppose. If you're seeing how effective a cooler is, then that's good, but if you just want to measure one against another then you generally just need a consistent form of measure across all products.As I said, I test and review lots of cooling components .. and I use the air temp going into cooler recorded at at same time as I record CPU / GPU temp for baseline temp, not the room ambient.
I disagree - It *seems* louder for the same reason you don't put the mic in the airflow. It's not actually louder, of course, you're just picking up more of the noise when the airflow is directed toward you, but again, as subjective as the rest of it.Indeed, air flow / wind carries sound, but it does not 'make it seem louder'.
No, but in the absence of buying twelve of each fan from each manufacturer and trying them all out, we have to start somewhere... and I generally find that's enough to make a quick comparison sufficient to inform a puchasing decision.Manufacturer's rating have little to no relevance to the sounds we hear from our fans in our uses.![]()
Or more importantly, what makes the same fans sound totally different.Many people do not realize how different fans sound in use
I (usually) find pull makes for a less turbulent airflow, for this reason.Most users have no idea that push versus pull sound difference is largely the result of the fan's motor mounting framework giving 3-5mm more spacing between impeller and what fan is mounted on when pushing then when fans is mounted to pull.
I'd consider those wherever there's any kind of gap between fan and rad, really. More for sealing the airflow and reducing the little noises of air escaping, rather than any 'vibration dampening' like they're sold as.I often use the thick (3mm ish) fan 'gaskets' on radiators to lower fan noise.
) a pretty good idea of how 10+ fans will perform. Sure, there may be a few unforeseen differences in different systems, but not many. I can see how case vibration harmonics and maybe impeller harmonic if too close to vent / radiator surface might develop but not very often.
