I don't recall anything like that at all.
mrk said:The E30 racecar version handled better than the road version iirc
Allow me to refresh your memory..
Been looking at cheaper service options via BMW's website but whilst it recognises my cars reg number (2000 e38 735i) I'm directed to contacting my dealer as it appears "value" servicing isn't available for the 7 series, am I missing something?
It's got full BMW s/h and given it's only done 56k I'd like to keep it BMW if it's not going to prove too extortionate.
Ah, fair one.Allow me to refresh your memory..
Did you fit them yourself? Maybe you made a mistake / didn't grease the right bits.
Thought as much! Was going to stockpile some parts from ecp when they next have a massive discount on.Real OEM tells you the part number, but not the maker. You can easily google the part to get to the OEM maker though,. but BMW also used multiple makers to produce the same parts over the years. Brakes being a prime example (Pagid, ATE and Textar).
Some pads are just noisy, Carbotech XP8 I had were amazing, but so loud squealing on light braking unless they were really hot
