Hmmm, I have one of those psu's. Didn't completely get what he was saying, but does it boil down to 'bad psu'?
Silicon lottery are also experiencing these vrm issues. I don't think its the PSU mate.
looks like my dream of a x299 build has gone to ****. need to sell off all my spare/high end parts and just have one system![]()
No offense mate and I know it's your money so do what you like with it but... You already have a blazing fast gaming system your not going to gain much by switching in that respect. If you really need multi core just get yourself a cheap ryzen 1700 set up and have the best of both worlds for little money, heat and power consumption. You had issues in the past but things have moved on a bit now you'll be fine![]()
That sucks but if she's worth it then it's no big thing. We all love our pc's but it not the be all and end all. look at it this way when your situation changes again their will be even better stuff on the market.
more annoyed as I'm the kind of chap that enjoys buying new parts and was getting excited over choosing bits etc.You have way too much to begin with. No one needs a 1080ti and a Titan xp, that's just greedyyeah I know real life and allmore annoyed as I'm the kind of chap that enjoys buying new parts and was getting excited over choosing bits etc.
thankyfull a few friends of.mine will want most of my spares (things like AIOs, spare 1080ti) looks like the main thing I need to shift is my titan Xp, and see how much I can get for my 7700k setup as to what that would leave for editing rig.
You have way too much to begin with. No one needs a 1080ti and a Titan xp, that's just greedy![]()
https://www.kitguru.net/components/...-7900x-skylake-x-10c20t-cpu-indepth-analysis/
video:
400w when OC for an i9-7900x and 100 degree`s on air, cpu rolling back to stock only under AIDA64 and cinebench.
54% more power draw when overclocked vs Ryzen 1800x also oc!
The video doesn't make sense though.
Clearly the problem is that the heatsinks require airflow which they are not getting, especially in AIO cooling systems.
That is why when you introduce a 120mm fan without a heatsink it performs better. It would actually perform even better with the fan and the heatsink. Imagine running it without the heatsink and fan, the board would be begging for the heatsink back again. It isn't insulating the VRMs in anyway whatsoever.
This isn't something that is unique to X299 either. It is simply the immense power draw of Skylake-X which is making it more apparent.
tinytomlogan has shown der8auers results to be wrong, he plopped an AIO on 4 or 5 different x299 motherboards and benched his 7900x at 4.8ghz (so more voltage than what der8auer was pushing) and recorded temps in the 50s-60s on the vrms.
there's also a fair few owners on overclock.net pushing high clocks on the 7900x and all have said there are 0 problems with vrm temps.
apparently there was an issue with der8auers power supply, so he said he's going to rebench over the weekend.
Any word on why silicon lottery were experiencing the same as der8auer?
Don't be silly. 300W doesn't produce any heat. Intel have found a way around the laws of physics.
it sounds like his PSU was giving out 10V not 12V making the VRM try pull higher current = Hotter tempsDon't be silly. 300W doesn't produce any heat. Intel have found a way around the laws of physics.
I don't see how a PSU can possibly be causing additional heat in the VRMs. Heat is a function of energy going into the system and the resistance of that component. If a PSU was suddenly causing additional heat it would mean power consumption should be far higher than normal which it isn't. It would also have to be operating at higher then normal voltages/currents which would have very severe consequences.
Are we going to see any cheap boards under £200 for Skylake-X?
