Permabanned
3000mhz if luckyI have Corsair 3200Mhz, Samsung E-die. Would they run at full speed?
What speed would i likely to reach?
For ryzen 130 would have been enough year ago. So just buy cheapest whatever or those new 8pack ones for 17x no middle groundSorry guys, I know this is a Overclocking forum, but could anyone suggest a pair of 8GB DDR4 (16gb total) for a Ryzen 1600 with a B350M Mortar Artctic MSI motherboard that works out of the box without needing to overclock ? I just really want the fastest compatible memory, I am not in to overclocking. I keep hearing conflicting things that 2400 is best but then some saying they have 3200 and so on, arrgggh, brain hurts. Youtube only seems to deal in overclocking. My PC would be for video encoding so just need something I can shove on the M/B and it works. I don't even understand why the letters "OC" are in brackets on the MSI website beside the compatible memory, does this mean to reach that speed it needs to be overclocked or does that mean it is OC'd out of the box. I am new to Ryzen and building my own stuff. Looking to spend around £130. Thanks all !!
3200 is sweetspot after that u can get diminishing returns on cpu oc. There is gr8 setting for 3200 14/13/13/13/28 if ramkit can pull it off that is2400 is too slow for Ryzen, should be targeting either 2933, 3200, 3333, 3466.
Fingers crossed will be building my PC today. I hope for 2900+Mhz.Ofc 90% chance they wont run at 3200 at least they have not in my case. And most of people seem to have problem getting them to run at 3200
90% is a bit of an exaggeration. Many boards have no issues running them at 3200 (ASUS and MSI in most cases) after latest AGESA updates, other boards you are looking at 2933 or 3066, which is within spitting distance, and real world performance difference will be within a couple of %. For the price they are still a good buy, and future BIOS updates should get them up to full speed as other manufacturers have proven they can run fine on 1.0.0.6
True, it's a lottery still - even when using the same boards.Had them solid at 3066 on the Taichi just using the XMP and knocking the ratio down. Friend has the same kit on a Tomahawk running at 3200. Purely down to board and their AGESA implementation.
3200 with timings that high I'd say they are hynix.Anyone know what chips are on these? Single rank?
