Wired vs Wireless for gaming/Live streaming help?
16 Jan 2013
Stranraer
Hey folks how's it going so basically im looking into getting this Motherboard https://www.overclockers.co.uk/giga...ocket-am4-ddr4-atx-motherboard-mb-553-gi.html for my Upcoming Ryzen/Vega build although it doesn't include WIFI :(
Im currently using my Phone tethered to my Computer for internet but am getting BT Fibre put in next week.
So i hae 2 options i either purchase this https://www.overclockers.co.uk/asus-pce-ac56-dual-band-wireless-ac1300-pci-e-adapter-nw-088-as.html and run it on wireless? also would this Interfere with my NVME drive?
Or i Pay someone to run a cable from downstairs to my Computer so i can use the Killer E2500?
OP
16 Jan 2013
Stranraer
Just Looked up Powerline adapters never heard of them before but they sound good i have a second socket in my room so could just buy a longer Ethernet cable for the second adapter would that work?
29 Dec 2002
Wifi is a convenience for mobile devices that have no other option to connect to a network. Wire everything else.
If you do use powerline then understand the quoted speeds are full duplex, so half them, quoted speeds are the maximum theoretically attainable, so budget on a minimum of 20% less in the real world, even less if you have crappy wiring, plug into extensions, spur sockets etc. and then allow for a networking overhead. Either way I'd take powerline over wifi.
OP
16 Jan 2013
Stranraer
Just Ordered BT Infinity Fibre not getting Installed/activated till October my estimated minimum speeds are like 35mb down and 5mb upload if i was to use the Powerline adapters how much speed would i lose theoretically?
29 Dec 2002
Unusual that you'd get near full download and only half upload. You'd probably loose nothing, but that assumes you buy a suitable kit, have OK wiring, RTFM and can follow basic instructions/have common sense.
15 Aug 2010
N. Ireland
I'm with VM with a 200/10 package.
Using powerline adapters give me a 50/10 connection in a recently renovated apartment.
11 Jun 2003
Hampshire
Wired > Powerline > Wifi.
I laid cat6 when the conservatory eas being built, and that's where my rig is. Best decision I ever made.
Running cables is easy if you're handy. The more they're hidden the trickier the job. Mine are all in walls, skirting or in D-Line trunking, as... you know, wifey.
I've never used power line so I can't comment as to their efficacy. Some love it, some have endless problems.
18 Oct 2002
N.Devon
I would easily take GOOD WiFi over powerline any day.
