ESXI experts - opinion 10GB network copy speed 90MB/s
17 Jul 2008
enterprise class storage
HP G8s blades
testing in out prod and preproduction (so unused) environments gives the same results
inter vm (windows 2008 r2) on the same host gives me a copy speed of 90MB/s with a CPU usage of pushing 100% (on 1 core) - VMs are on the same virtual switch
we have the vmnet3 drivers installed
any thoughts do other people get the same sort of results?
9 Aug 2004
Sea of Dirac
chuck more ram and cores at it and see what happens.
after that it's checking on the host for disk write/read issues and provisioning. making sure you have driver's for the disk controller and not broken old vibs installed.
18 Oct 2002
What ESXi version and build are you running?
I've come across this but I can't remember what fixed it. I think it might have been an ESXi bug fixed in a later build, or a HP driver bug
I would:
Set all Power Management settings to High Performance in the BIOS and inside the VM's.
Update the blade server firmware with the latest SPP.
Update the blade enclosure firmware.
Install the latest build for the version you need from a HP Custom Image.
4 Dec 2002
Chelmsford
Check the power management in the BIOS as mentioned, I had a real issue with a particular VM running MS SQL that was dog slow, turned out to be power management.
Check MTU sizes.
Could be CPU related as there is no TCP offload in VM's so more reliant on CPU, throw another vcpu at it and see if that helps.
90MB/s sounds like something is configured at 1GB/s - Make sure none of the NICs have negotiated at 1000mb/s
Caporegime
18 Oct 2002
Don't write "enterprise storage" and then not expand on that. What is the storage? What relevant statistics are being shown when doing this? What happens if you create two new Server 2016 guests and try again?
If you storage vmotion the guests to a local datastore (assuming one exists) then what happens?
26 Nov 2002
Romford
I did the same test, and you get nowhere near 10GBe speeds, but 300-400MB's should be expected.
Using ATTO or iometer from inside a VM, what sort of performance do you see against your `enterprise storage`?
OP
17 Jul 2008
Check MTU sizes.
Jumbo frames get me 200 - 250 MBS copy speed but our physical switches don't have that so it only helps vm to vm on the same host (so not configurable)
CPU seems to be able to max out 1 and only 1 core - dual / quad makes no difference - I was amazed to see 100% core usage! (xeon e5-2660 v4)
We built the G9s with the latest HP esxi 6 ISO..
ok someone has a point I've just spotted one of our environments can easily break the 1GB speed barrier, I think we have something to fix here!
Good to see people confirming way over 1GB speeds (lanz I see pushing those speeds in one of our environments)
Thanks for the replies ill pick up this "anomaly"
Man of Honour
30 Oct 2003
Essex
HP G8s blades
When you say ent class storage what is it? Are we talking EVA/3PAR? How many disks? What config on the disks? How is it connected? So many questions. I can do a quick throughput test on a very similar environment:
DL380 G7 Hosts
HP 6300EVA FC 10GB Dual Controllers
Also using vmxnet3.
Ill give it a go now see what we got.
Edit: Im seeing speeds in the 100's of MB/s on small files. I did start a bigger file and was seeing speeds approaching the gb/s between datastores.
OP
17 Jul 2008
DL380 G7 Hosts
Also using vmxnet3.
VMAX with £100k+ of SSDs + 100TBish of HDDs
8GB fibre connections
VMNet3 HP BL460 G8's
I think I have the important information which is - I should be seeing much better than 1GB speeds
18 Oct 2002
First thing I would do is remove storage as a bottleneck in your testing. I use LANbench, which should give you accurate throughput without the overhead of storage r/w.
Have done countless 10gb deployments, and usually anywhere between 5-8Gbps means it is working as intended with VMXNET3. The e1000e nic can also be used to test, as it will normally hit 2.3 to 3Gbps, which would confirm you are at least utilising a 10gb network. That would help you identify whether it was the vmxnet3 nic at fault.
I'd also be wondering if you are missing something simple if your speeds are consistent with a 1gb network. We did a recent deployment where our client left their vm gateways as a 1gb switch, which meant traffic left the 10gb network and was instantly gimped. Obviously easily resolved by making the 10gb switches the gateway.
