lmao, if only world was as perfect and simple as you imagine.
I'd rather drivers spend more time looking ahead than steering at their speedo to not 1mph over.
What's so difficult about driving slow enough that you know you won't exceed the speed limit? You aren't wrong that it would be almost impossible to drive at 30mph and not exceed 30mph. But nobody is suggesting that as a solution. A car with a speed limiter should be fine with the limiter set to 29mph or 30mph (depending on the car). Under manual control, I'd worry a bit if a driver isn't able to control their speed ±10-15% (so aiming for 25-27mph in a 30).
Personally, I don't really agree with the "not even 1mph over" idea. But I do think the current system is too generous. Around here, 10% + 2mph is taken as a given; it's the speed people are aiming for, rather than a prosecution buffer. Get caught going faster than that? Attend a speed awareness course and slow down to the speed limit + 10%. The system needs to change, but not to the extent being suggested. Reduce the buffer to +10%. Ditch the speed awareness course. It's a joke. People will become a lot more aware of their speed if they expect to get a fine and points on their license.
