vm is coax from the cabinet to your home
I thought the latency issue was a hardware problem that couldn't be solved by a firmware update.
My first thoughts were that this might the case, in that they've made a fix so the BBQ meter looks more normal but the underlying problem was still there. Though to be fair I've definitely, beyond a shadow of a doubt noticed great improvements in 2 areas.I've had a good read through some VM forums and the bottom line is that it is a hardware issue and it won't be fixable by software patching it.
Granted the most recent firmware being rolled out is really transforming how peoples ping responses and average latency graph as well as mitigating some 3rd party Puma6 testing tool but "real use" is still reporting the constant TCP ping spikes. I guess VM figured if the graphs look clean then people can't evidence an issue to them.
What's the best way to test my ping both wired and wireless. I ask because wirelessly with a new Asus router with sh3 in modem mode I get 150mb wireless now upstairs however seem to be lagging on my PS4 with ethernet in.
Sorry I'm not fully savvy with routers. Do I use a programme to read results or will this show in my router settings once I set up the QoS ?QoS your upload to a slight amount less than you speedtest at.
The old software version was 9.1.116V the new one is 9.1.116.603
I have also noticed that some of the photo intensive sites that I frequent seem to be loading faster. Hopefully that is not just the psychosomatic side affect of finally getting rid of this bug. If I'd know it was coming I would done some stopwatch tests.
I'm in the Midlands but I've historically got updates pretty quickly. I was among the first to get the now old .116V that fixed the port flapping (disconnect every 35mins) that was killing us a while back. Plus I was signed up about 7 years ago to beta test some Superhub firmwareWhere do you live (rough area) if you don't mind me asking? I wonder if they're live trialling it area by area? Just checked my HH3, still on 9.1.116V
