THREAD BUMP: New build garden - seriously where do I start!?
29 Dec 2004
Shepley
As above drainage will likely be a massive issue. We countered this by putting raised beds in for hedging around the outside of the garden and putting two drains in the lawn area which connect up to a sump pump and drain excess water into the drain.
Man of Honour
11 Mar 2004
If people think drainage is going to be such a massive issues well as mixing sand in, wouldn't it be a good idea to lay some perforated drainage pipe in connected to a drain?
Caporegime
25 Jul 2003
FR+UK
Was just thinking this! :)
When we rotavated before putting manure into in in front garden when redoing it a few years back (1970s build) we spend quite some time pulling every stone larger than a large marble out and putting them in buckets/wheelbarrows and then into a skip we had at the time.
We're going to have tons of bricks and various bits of debris in our garden once the building work is finished, but it's sunken a massive amount in the middle so we are hoping to get it to a certain level, and then we'll be shipping in some new soil with sand/peat/manure :(. I'm hoping it works!
6 Mar 2008
Stoke area
Depends on the size of the garden, surface runoff volumes and drain size. No good having it all run into the drain if the drain can't take it and you end up flooding the area anyway.
18 Oct 2002
Nottingham
I will be watching this thread with interest. I've just moved into a new build also and trying to decide what to do with the garden.
I'm surprised you don't even get any turf with the house though. Both our front and back garden were turfed prior to completion and some basic landscaping was done out the front.
https://www.dropbox.com/s/rxxpllc8nspkg4m/front garden.jpg?dl=0
https://www.dropbox.com/s/dqwzh1fhrsswvzg/back garden.jpg?dl=0
8 Nov 2002
Near Bristol, Uk
With quite a few developers these days its an optional extra... And in many instances you are better off DIY, as you can remove the debris/rubble and level it properly before the grass goes down.
23 Feb 2009
South Wirral
I'd add to the advice above to make sure you have a lot of weedkiller spray ready. This is just the time when they'll start growing and bare earth like that is like letting kids loose in a sweet shop.
As already said, there will be a lot of builders mess buried in there - I'd suggest pile it all up in one spot as you dig/rotavate and you will likely have enough hard core for a decent shed base.
OP
5 Apr 2004
London
I really appreciate all the replies sorry I’m at work so I can’t be more specific but I’ll try and keep the thread going to show what I do with it.
I queried why we don’t get grass and the sales people said they used to do that but they found everything would just die and people complained so in a way I’m glad I get to DIY it. Not saying I’ll succeed but I’ll have some fun along the way!
They have made a front garden but I think that’s looking a bit fragile so once I learn how to prepare the ground I might dig it up and do the same before replanting the turf, shrubs and tree that are there. Would be a shame to see a young tree die!
8 Nov 2002
Near Bristol, Uk
To get an idea of what to expect in the back garden, get a spade, pick a spot at random and start digging... You wont have to dig down far before you find the usual 'building site rubbish' hidden underneath your top soil. Normally the top soil they add is 15cm max.
18 Oct 2002
Nottingham
I did some playing around over the weekend and this is what I have come up with currently. Hope this helps with a few ideas!
I overlaid two models so the walls/roof don't tie up in all areas but gives the idea.
25 Mar 2004
Fareham
Have a new build garden and it's not well drained as per other comments.
Came with hilarious amounts of rubble in the soil, big stones and junk.
Also find it a right pain to mow the lawn when the lawn is fence to fence, mowing along a fence line is annoying. Consider putting "something" on the left so that you don't have to mow right up against the fence.
8 Nov 2002
Near Bristol, Uk
And give thought to lighting/power... SWA cable run to the patio/decking area for some sockets (so you can have music/charge things) and some power provision for lighting the path/decking as well.
SPG
SPG
28 Jul 2010
Hire a rotovator and a grab bag
Get rid of all the crap builder has left in back garden
Use the rotvator again with a 3-4 ton of manure and gravel
Leave it alone for a year with some black hessian on top.
Lay down slabs where you sit in the evening sun, while the above gets to work. It may not seem it but this wait will pay dividends for a much better garden area in a shorter space of time than just doing it now.
8 Nov 2002
Near Bristol, Uk
@Abyss good effort!
I'll certainly post some pics when I do something / come up with designs but I appreciate all the ideas in this thread
Just make sure whatever you do that you rotavate, remove the rubble/rocks/waste etc and add some organic matter (manure) and sand/gravel. You are at a point now where that is easy to do, it gets much harder once you have a garden of some sorts in place!
OP
5 Apr 2004
London
I've been thinking about the garden for the past 6 weeks and this is version 3 of a design I've been tweaking. Thought I'd share to get some feedback
1 Apr 2014
Aberdeen
That sketch looks far too busy. Keep it simple to start with. You can always add stuff later.
Anyway, a bog garden? Really?
Your renderings look much more sensible, though I would suggest climbing plants or trained trees on the fences and the walls, especially for that awkward strip between the patio and the far fence. A bed of some sort will be much better than a strip of grass. For the patio, instead of decking, consider coloured paving slabs.
Can you mount a trellis on the back wall of your house? Climbing plants could look wonderful, though you will want to ensure that there's no risk of dry rot from a raised bed beneath.
