Anyone else use Smart Queues on the USG and find they suck?
They're supposed to be pretty awesome. I personally don't trust any platform to tell me what has priority and what doesn't but for the most part I hear they work well although do take a huge chunk out of performance if using the USG3.
Aye I think thats my likely route, was hoping to avoid the expense of the 16 port PoE switch though . Suppose I'll be able to sell the other one though.They don't do an 8 port non POE with SFP. I'd be more inclined to get something like the 16 port 150W and sell the 8 port you already have, 1 single unit, full PoE capability and that I think has 2 SFP slots.
Do you have s link to the brackets ?
Edit. You mean this one.
https://store.ubnt.com/collections/accessories/products/unifi-professional-mounting-plate
Was after an ac lite spare bracket really.
I've set mine to my max connection speed minus about 10% and the internet just seems a lot slower since I've done it.
I think that's the issue then, when all are on I also see around 35 Mbit down, I think I'll turn SQ off and then set nzbget to around 75% of my connection. Most downloads are overnight so it doesn't matter too much, but doing it this way it won't steal everything if it's downloading during the day and I'm trying to stream Netflix!I've just done some testing on the USG at work. With IPS and DPI throughput maxxed out at about 72Mb, I put smart queues on and put them to about 60Mb and the throughput plummeted and came back between 30 & 35.
I tried combos of all, smart queues is the killer.
The long of it is I think UBNT are onto a winner now and I would happily put this into action if the "lower end" hardware was improved to at least do 100Mb throughputs.
If it's the same one, i don't plan on using the one i got with my AP Pro if you want it?
EDIT - Mods not planning on selling for money so i think thats ok to post in here?
Really kind of you mate, will ping you a trust message nowIf it's the same one, i don't plan on using the one i got with my AP Pro if you want it?
Quick one, other than cost there is no reason to purchase the uap-ac-lite over the uap-ac-lr right?
Nice comparison chart here;
https://www.broadbandbuyer.com/advice/3776-ubiquiti-unifi-uap-ac-comparison-chart-indoor/
I see two interesting things on there:
- There is no difference in the chart between an HD and SHD (I guess there must be something).
- They give a two year warranty on the IW. I'm not sure what to infer from that but it stood out.
Thanks, I have one LR at the moment so might get a lite to compare and see how they work for coverage. I don't have the LR mounted at the moment, just sitting on top of the radiator cover
