I have a situation with my Golf which has got to the point where I need to make a decision on whether to continue fixing it or just walk away. I'd be interested in opinions before I make a rash decision.
Car
2009 VW Golf GTI
Approx 90k miles.
Value (if running): I'd guess about £5k to £6k. This is just a guess and I may be wrong.
I am the second owner. The car was bought as approved used from VW approximately 6 years ago.
The car is in generally very good condition apart from a scuffed front wheel.
Leather interior (only mentioned in case it alters resale value as that's fairly unusual)
Other expenses due...
1) It is due for an annual service and MOT imminently.
2) To pass the MOT I need to replace the front discs and pads, and also the rear pads.
Background
About two months ago the car would not start. There are no fault codes showing. The RAC could not diagnose it so I had it towed to my regular indy garage.
The car appears to be massively over fueling. They found a small amount of swarf in the fuel system and suspected this may have damaged the injectors. So far we have replaced all four injectors, the high pressure fuel pump (which could have been the cause of the swarf), fuel filter and fuel, with the fuel system being flushed out. After doing this the car started and ran OK for a short time while it got up to temperature. The next day they road tested it and it spluttered, then failed to start again. Before replacing them we did have a conversation that they could not be sure they would fix the issue but appeared to be the most likely cause. So I am not at all complaining about this work. It was my decision along with their guidance. I took a chance and it didn't pay off.
No fault codes have ever shown (one minor fault code does show with the radio antennae, indicating the fault code system itself is working)
After considerable testing the garage have not been able to diagnose the issue. The garage is run by ex-VW mechanics and an ex-VW 'master-tec' and I have used them for many years. I trust their work and have a good relationship with them. They have been doing most of the diagnostic work for free. Several mechanics have looked at the car and started right back at basics checking compression, fuel pump, spark, etc, etc. They have also taken the car to another garage they work with for a second opinion but they were unable to diagnose the issue.
The car has been with them for almost two months with regular updates about what they are checking and testing. So the garage has put considerable effort into it.
Options
1) Start replacing random parts... The garage have advised the next step would be to have the ECU tested. However they have also said that in the past they have sent ECU's away for testing and they have come back as OK, despite later being found to be faulty when they have finally replaced it. So while they are happy to offer this option they advised the test results are not always accurate and it may be better to replace the ECU with a known working one. There is no indication the ECU is at fault and after replacing it we may be looking at trying something else. But it is their next best opinion after the injectors and fuel pump.
2) Take it to VW to see whether they can diagnose it. The current garage advise they do have access to the same diagnostics equipment which the VW garage would have. Once at VW the costs will start mounting considerably.
3) Quit my losses, sell the car as not running and just move onto something else with the little money I recover from it.
Money is quite tight at the moment as we are pilling everything into refurbishing a house. So none of the options are ideal. Therefore the worst case scenario would be to keep chasing a fix, incurring additional cost, and eroding any money I have for another car.
Opinions? Thanks.
Car
2009 VW Golf GTI
Approx 90k miles.
Background
Options
Opinions? Thanks.
Thats the point I reached when I gave up with it
