Carbide Series SPEC-04 Mid-Tower Gaming Case — Can it fit this ATX motherboard?
15 Dec 2002
In a cowfield, London, UK
Hi All,
I'm doing a basic build for a friend of mine. I've specced up a case to match up with the motherboard below. Could someone just verify if this mobo will fit it? Thanks guys.
Mobo Dims: ATX (305 x 230 mm)
Case Mobo Compatibility: ATX (Up to 272mm) - The 'upto' is throwing me off. Am I correct in assuming this refers to the horizontal mobo length? (in this case 230mm)
https://www.overclockers.co.uk/giga...ocket-am4-ddr4-atx-motherboard-mb-557-gi.html
https://www.overclockers.co.uk/cors...ase-black-yellow-cc-9011108-ww-ca-23j-cs.html
OP
15 Dec 2002
Gone for gtx 1060 on deal for £220 or gtx 1080 for £450? Haha
Not sure of your budget but on sale
https://www.overclockers.co.uk/cors...k-tempered-glass-cc-9011121-ww-ca-23p-cs.html
Glass over acrylic panel so doesn't scratch and colour matches nicely
I actually specced him an Asus GeForce GT 1030 OC lol. This chap is a writer so he doesn't really need any graphical power for the most part. I'm seriously tempted by those 1080 deals to replace my aging GPU though but I'm resisting!
I was going to order that Corsair as I do love their stuff (800d owner here) but I went with the bumblebee case as it'll be going under a desk and there isn't much height room down there.
1 Dec 2015
gtx 710/30 on ocuk for £25/35 if i recall :D
1 Dec 2015
Indeed, though I confess I wasn't sure how good they were on the performance end of things hence the 1030. Ah well, can't change it now because ocuk have already shipped the lot already! :o Cheers dude.
no worries, to be honest if its jus for displaying on the screen then it'll do fine . currently have one till next gen rolls over and 1160gtx makes it way to us - young kids so can hold out til beginning of next year
