** SWEET SWEET AIRFLOW - INTRODUCING THE KOLINK LEVANTE **
OcUK Staff
26 Nov 2014
Stoke
Available in stock today, we have the brand new Kolink Levante. The Levante has a completely open mesh front panel, to allow for significantly more airflow than it's solid panel counterparts. Added to that are four of the popular Rainbow Addressable RGB ring fans with a fan controller that supports up to 6 fans and 2 LED strips. These are the ones that come with the Observatory, and have the same modes and colour options. The Levante has dual tempered glass side panels, with the right hand side covered with a dark black film tint, only showing the space for a pair of 2.5" SSD's. Added to this is an improved top panel structure with venting on both sides, space for 240mm radiators at the front/top of the chassis, 380mm VGA support and room for up to 5 x 2.5" drives (3 of which can also fit 3.5" drives) leaves you with another excellent price/performance case from Kolink.
The Levante is available for order today!
Kolink Levante Midi Tower Airflow Gaming Case - Black Tempered Glass @ £72.95 inc VAT
Impressively designed Midi Tower case, includes 4x 120mm Ring Rainbow RGB fans, bundled with RGB lighting controller and remote control, tempered glass right and left side panels.
Only £72.95 inc VAT.
ORDER NOW
31 Dec 2006
They've clearly nicked that top panel off an Evolv lol! And it was a real choke point for airflow... although that front section is clearly goinog to do a much better job.
24 Mar 2018
Brighton
Whats the measurement from the standoff to the inside of the glass. Also what speed do the front fans run at and are they pwm.
Got a big cooler 165mm in height and it just about fits into an RL06 (very tight against glass) hence the question.
RGB is my worst nightmare but I like the Airflow potential of this case.
1 Dec 2015
looking at the Evolv and Lenvante below- Evolve is wider and accepts 194mm taller CPU coolers. safe to say this will house 160-165mm just fine
24 Mar 2018
Brighton
I found a bit more info on here https://www.caseking.de/en/kolink-levante-midi-tower-tempered-glass-black-window-gekl-038.html
My Focus now is to look for the Fan RPM and quality there of.
@orbitalwalsh looks like a tight fit @160mm (specs below), I Reckon by looking at those pics you posted the IO sheild is 45mm+120mm fan which leaves a bit spare.
Technical Details:
  • Dimensions: 206,5 x 440 x 475 mm (W x H x D)
  • Material: Steel, tempered glass
  • Weight: approx. 8,1 kg
  • Colour: Black
  • Form Factor: E-ATX (up to 279 mm wide), ATX, Micro-ATX, Mini-ITX
  • Total Possible Fans:
    3x 120 or 2x 140 mm (Front)
    2x 120 mm or 2x 140 mm (Roolf)
    1x 120 mm (Rear)
  • Pre-Installed:
    3x 120 mm RGB (Front)
    1x 120 mm RGB (Rear)
  • Radiator Mountings:
    1x 240 mm (Front)
    1x 240 mm (Roof, certain limitations may apply when using certain sizes of motherboard or RAM modules)
  • Filter: Roof, bottom
  • Drive Bays:
    2x 2,5" (internal) 2x 3,5/2,5" (internal)
  • PSU: 1x Standard ATX up to 200 mm (optional)
  • Expansion Slots: 7
  • I/O Panel:
    2x USB 2.0 (internal connection)
    1x USB 3.0 (internal connection)
    1x Audio In/Out
  • Maximum GPU Length: 380 mm
  • Maximum CPU Cooler Height: 160 mm
24 Mar 2018
Brighton
It all depends, my RL06 said 158mm coolers yet I have an 165mm cooler in the case which is only 200MM wide vs 206.5mm Levante.
RL06 Dimensios:
Dimension 200mm (W) x 477mm (H) x 455mm (D), 43.4 Liters
7.87" (W) x 18.78" (H) x 17.91" (D), 43.4 Liters
Expansion card Support graphics card up to 348mm
Limitation of CPU cooler 158mm
Limitation of PSU 200mm
Thats why I asked for a measurement, but if Overclockers can't be bothered to reply then it's a no sale situation which is a shame because it's what I'm looking for. Cheap and functional with good Airflow by the looks of it.
