- 4 Aug 2018
- UK
Looking for some help as to what to look for next as I'm running out of ideas.
Right now I can get at most 10mins of seemingly normal use before it switches off instantly with no warning. It doesn't seem to matter what I am doing - just with Windows loaded, or even had it power off just while in BIOS.
Intel i7-2600K (stock)
Gigabyte GA-Z77X-D3H
16GB (4x4) Corsair Vengeance DDR3 1600MHz
Gigabyte Windforce GTX 670 2GB
Coolermaster 700W Silent Pro (swapped to Corsair RM1000x)
Samsung 850 EVO 1TB SSD + 2 x 1TB 7.2k HDDs
Windows 10
Starting a few months ago I could use my PC normally no problem until I shut it down. Then if I tried to start it again it would be temperamental. Sometimes it would start, sometimes get absolutely nothing. As I have seen from other threads pulling the power cord, pressing power a few times and plugging back in usually did the trick. (It did sometimes fallover in Dual BIOS, but a thread here about power+reset to clear corrupted BIOS worked to resolve the dual BIOS issue.) I tried updating my drivers and updated the BIOS, but still had the same issues.
Originally I was using a 700W Coolermaster Silent Pro PSU, but had managed to grab a Corsair RM1000x for a future build from Maplin while they were closing down. Suspecting either PSU or mobo, and having a new PSU, I installed that. First couple of days everything seemed good, then we were back to needing to unplug from the mains to get it back on. Seems PSU not the problem.
Then a week ago for the first time it completely shutdown mid game with no warning, as if there was a power cut (but there wasn't). Since then the longest I have been able to get my PC to stay on is about 10 mins, then another instant power off. Sometimes it will choose to power back on itself after a minute, but while it may get into Windows for a few minutes, will power off again.
I was able to keep it on long enough to use HWMonitor to confirm temps are all fine. CPU 40-45C, GPU under 40C, harddrives and case temps 20-30C. No alarm bells there. Also seeing same sort of temps in BIOS. Using a TRUE 120 air cooler & 120mm fan. Just booting into Windows and leaving it there it will power off inside 10 mins so not even a demanding application running.
I found an identical model mobo on ebay (used, claimed working), moved everything over to it today, powered on and had 10 mins of "thank god it worked", before instant off and a flurry of swear words. It seems the problem is still here. New mobo had had BIOS reset by the seller, so not old settings interfering and I also went in to check them. It was updated to the latest BIOS already, and all setting back to stock / Auto, so should just work. RAM at 1333 rather than XMP 1600, but should be fine running slower for now.
Moved CPU to a new mobo. Cleaned off old TIM and applied fresh. securely remounted the heat sink and air cooler (TRUE 120). In the limited time I have had it running again HWMonitor confirms temps back in the original range albeit a bit higher due to current weather. If it was thermal cut off I would be expecting temps 90+, not < 40C.
Checked power connectors from PSU. 20+4 pin securely in on the motherboard. 4 pin next to CPU firmly in. 8 + 6 pin on GPU firmly in.
I tried removing pairs of RAM and retesting - same results - on for up to 10 mins then powers off. Swapped pairs, swapped slots, same results. Seems not the memory at fault.
Read in another thread about power button / reset button failing. Tried swapping the pins to reset button - powered on, still shut off a short while later. Removed the front panel from the system and jumped the pins - came on, and still powered off a few mins later with no front panel attached.
I'm running out of ideas as I can't think what is causing it. I can get it to power on and get into BIOS and Windows, seemingly fully functional. I don't see anything odd when I get there - no display errors, no temp warnings, and HWMonitor figures all appear as expected, until the screen goes black and the PC stops.
Any clues as to what might be causing this or what I can try next?
Windows 10
enough that its just the battery(ies).
