PHANTEKS GLACIER R160 RGB RESERVOIR
11 Jul 2003
Telford//west mids
Looking at buying one of these for my watercooling build in my phantek evolv x as if will be fitted on the front intake fans.
Also it does say a d5 pump can be installed in it but I've not seen any reviews with one fitted.
Has anybody bought this at all?
Thanks.
OP
11 Jul 2003
Telford//west mids
It says both on the shop and also sent a email to them to see it the d5 did fit the the res and they comfirmed it,just waiting to hear back from phantek support,but I'll go for the ddc and buy the ek aluminium body kit for it.
Only problem now is what ddc to get there are so many 's Ince I last used one.
28 Dec 2017
Beds
Do you mean DDC or D5? I have the more recent Alphacool D5 which is incredibly quiet but has mixed compatibility. VPP755 if you want to take a look. I'd recommend confirming with Phanteks that it will fit as it's got slightly different dimensions to a Laing D5.
