Caporegime
- 21 Jun 2006
I have an older version of this
https://www.amazon.co.uk/Modern-Bathroom-Shaver-Socket-Switch/dp/B01H3SOCFK?ref_=fsclp_pl_dp_4
want to replace with something like this
https://www.ikea.com/gb/en/products/lighting/bathroom-lighting/ledsjö-led-wall-lamp-stainless-steel-art-40359761/
I take it I need to buy a switch as the light doesn't have one yet the old one did that is a given. What type of switch can I use inside a bathroom? It will get some condensation, etc.
I have a hole in wall with 2 wires which split into 3 wires each. 2 earths wrapped around each other going into thin air. 2 positives 1 from each wire connected to each other going into a electrical connector and the same for the negatives. So this then means I had 1 positive going into the shaver light and 1 negative with no earth being used.
The wires I have now are live with no way to turn off.
My idea was to buy a fused switch like this
https://www.screwfix.com/p/mk-13a-dp-switched-fused-connection-unit-with-flex-outlet-white/13479
stick it inside a cabinet and then use that to connect to the ikea light above.
All wiring will be outside of the wall hidden inside of cabinet. Some slightly external going from switch to ikea light which will be placed directly above cabinet. Is that okay? As in a like a cm of wire in the bathroom going from switch inside cabinet to the light. Or does it need to be in behind the wall?
