Spec me a 250gb SSD please
Man of Honour
29 Mar 2003
Stoke on Trent
It's a minefield out there ranging from about £37 to over £100 but what is the difference between the cheapest and say the Samsung EVO for around £55?
And then what is the difference between the Samsung £55 and £71?
At the moment I use a Samsung SSD 750 EVO 250GB but the problem is it's divided up as a 60gb C:drive and the rest is an e:drive but I now get all types of 'not enough HD' errors and I haven't got enough space to put the latest updates on.
The reason it's 60gb is because I originally had a 60gb SSD and used a cloning device to clone it to a 240gb which put the rest on e:
If I could combine the two drives together (what software would I use?) but I'd probably have to reinstall all the stuff I put on the e:drive anyway.
There's a few questions there so thanks
Don
21 Oct 2002
Parts Unknown
Personally, I tend to go for Crucial or Samsung, depending on the use.
Samsung for system drives, Crucial for data (they tend to be cheaper per GB, but a tad slower).
Doing anyone would notice the speed difference outside of a benchmark.
Handy tool for freeing up space.. Treesize Free, it will tell you where the storage it's being used up.
Man of Honour
OP
29 Mar 2003
Stoke on Trent
I will go for Samsung since I've got two others but what's the difference between the £55 and the £71 drives?
I use a program called DOPUS (Directory Opus) that has a Treesize built into it and I can't see where I can free up any space so I'll start again.
5 Oct 2009
Spalding, Lincs
You would struggle to buy a bad SSD these days, I have SanDisk and Kingston drives in a server performing brilliantly.
Samsung drives are definitely very good, and generally the more you spend they are quicker and have higher write endurance.
26 Nov 2009
Why don't you back up e drive then delete the partition in disk management then extend c drive.
27 Nov 2005
Guernsey
