Issues? Other than the coolant pipe replacement what other issues are there?The reliability issues have been known about with the 1.0 for some time though.
https://www.whatcar.com/news/ford-ecoboost-engine-recall-–-what-you-need-to-know/n17972
EDIT:
There has also been a recent recall for the Focus with 6 Speed Manual gearbox relating to clutch slip/overheating
A batch of early Focus 2.3 were fitted with the head gasket designed for the Mustang 2.3 - there are some differences in the coolant passages which caused overheating.Anyone know if the coolant loss problems with the 2.3 RS engine is the same problem ?
(Maybe it was a completely different problem as the recalled fitted new head gaskets on the RS engines)
http://www.thedrive.com/sheetmetal/...cus-rs-head-gasket-issues-has-been-discovered
that’s not the same as seeing thousands of 10-18 year old examples still running around without any problems. If you read my post properly i didn’t say ecoboost engines won’t reach that mileage I said i just can’t see there being a big number of them around in 10yrs time or hitting big mileage and still going strong like the 1.6 did in the mk1/2. You seem to take offence whenever I diss the ecoboost engines even in the past but I have owned 6 Fords in my 7 years of driving I love them but I wouldn’t buy a 1.0 ecoboost.
