Lens pouch for Fuji XF lenses? Need to order today!
20 Oct 2002
London
Looking on the rainforest for a set of cheap neoprene style pouches but I'm struggling to find ones that might be suitable for my XF 35/f2 and XF18-55. And actually, my Nikon 50/f1.8D with adapter (which I'm reckoning is pretty similar to the XF18-55 size.
Best looking I found was these Lens Aid ones -- a bit more pricey but they look cool and I can order the set with XS/S/M. But with the XS pouch being 7x8cm and the S being 8x10cm I'm wondering if the lenses might just rattle around? What do you think?
The 35/f2 is 6cm diameter by 4.5cm tall
The 18-55 is 6.5cm diameter by 7cm tall
Hmn...
OP
20 Oct 2002
London
Agh the ones I was looking at take like a week to ship (thanks, Amazon Prime :rolleyes: ) and I need them for Thurs. I have a proper case for my Sigma 70-300, I might just bubblewrap them and put them end-on-end in that :o
OP
20 Oct 2002
London
25 Nov 2005
Erm. "This item has not yet been released" ;)
Anyhoo, I thought it'd be useful to take my camera bag insert in my rucksack so I've chucked the lenses in a cloth case thing and into that. It'll be fine. I might go for some lens pouches at some stage though, I'm sure they'd be useful and £10ish for a set you can't really argue.
Meh it was late :p
If you can wait on delivery from China, you can pick them up for around £1.50 a pouch off aliexpress I've bought a couple of these in the past https://www.aliexpress.com/item/1pc...pm=a2g0s.13010208.99999999.266.28c93c0030qvHp
6 Mar 2010
Not being funny, but have you even bothered to read the OP at all? It literally says in the title "Need to order today!", so you suggest a product that is on pre order, and then a product from a country that's one of the furthest away from the UK?
