What's your highly rated sleek/simplicity case?
9 Nov 2011
I've been looking at cases but would like to hear from others incase I missed a good one.
I'm looking for a decent case which is:
  • Sleek and plain, dont really want fancy stuff, no weird bevels, protruding parts, weird/whacky shapes, the more plain, nice/elegant looking, the better.
  • The more the price is kept down the better, but if you think the price is worth every penny then please share.
1 Jul 2016
What's your budget, and What type of case are you looking for? - Silenced/airflow/watercooling support etc
OP
9 Nov 2011
Between £30-£100 but the cheaper the better if its not sacraficing too much quality.
Don't really need watercooling or anything special could be a standard case with regular fans, as long it doesn't sound like an airplane lol.
The most important factors are a plain simply nice looking case + saving as much money.
26 Sep 2018
I recently got a fractal design r6 blackout without a window as I wanted something well built that didn't look ridiculous.
Very happy with it, super easy to get everything tidy and has a bit of a 2001 monolith look to it.
The only possible negative, is that it's huge. Probably not dissimilar it's contemporaries, but I'd been reusing my previous case for about the last 15 years and things seem to have gone big in the mean time.
Man of Honour
26 May 2012
it's cheap, build quality is so-so, decently looking, but thermals are an issue as the case doesn't have very good ventilation
OP
9 Nov 2011
Hmm this guy seems to be happy with the temps, do you mean for more like extreme OC builds? I think im going to stick a ryzen 2700x in it. Probably could get away with it. it's £35 total with delivery which is pretty damn cheap.
https://youtu.be/O_6RmNBkiyQ?t=1252
OP
9 Nov 2011
Do you guys know any more cases similiar in simplicity and around the £50 budget range I could consider in comparison to the Kolink? Cheers.
7 May 2012
Bournemouth
I've just sold my Cooltek U3 Micro ATX for £30, which is the sleekest/simplest/smartest case I've ever had. Great quality case, but only space for a max 260mm long GPU, hence the upgrade.
