Caselabs BH4 - Water Cooling Issue.... HELP!
9 Aug 2015
Cambridgeshire
Hi Guys,
I have built another Caselabs (RIP) BH4 mATX build - this time with a 1080ti and 8086k - fully custom cooled. I have a horizontally mounted EK XRES 100 to the rear fan are at the back of the case.
Here is my problem - I cannot seem to get it to run without air bubbles in the loop for any amount of time... I have emptied and refilled the loop several time for it to be fine for a bit and then low and behold there are the bubbles again.....
Any ideas please?
Cheers
Ras
28 Nov 2011
There is more air in the loop after it has been run for a while?
Is it properly bled? If so, you have an air leak.
I have run the EK res horizontally without problems.
Is yours a pump/res combo?
28 Dec 2017
Beds
If you just mean air bubbles clinging to the sides of the reservoir, I've found those can take a few days to let go and find their way to the air pocket at the top. Quite annoying when you're finally filling your loop!
Otherwise let's see some photos :)
