Speaker purchase/setup advice
22 Nov 2010
Recently built my cousin a PC for use as a golf simulator. The setup would also function perfectly well as a cinema room. I'm not so into audio except iems so have no clue on what kind of setup would work well?
I'm assuming some sort of external amp could be plugged into the pc easily? 3.5mm jack??
And then the amp feed the speakers.
Could anyone recommend anything .
Say £200 budget? Not sure if that's adequate?
23 Dec 2009
RG8 9
The amp is fine to power those speakers and the speakers can fill a room easy. Had some Diamonds for years which I bought in 1997. 7.1's I think. A friend still uses them with and old Cambridge Audio AM1 amp (which was also mine) and it is a banging little setup. That little amp has more power and a built in DAC, bit of a bargain really, I quite fancy getting one myself even though I have no need.
