The RX Vega 56 Owners Thread
16 May 2007
you should lower the volts too, its not just about heat, it does reduce temps, but also power and noise etc, so its worth doing. most cards should be able to drop 100mv of each p state without much issue.
That's very true, at the moment the max mine hits is 1.09v so I could lower the volts to 1.1v for the top Pstates easily enough but as I am not playing with the power level at the moment I have left it as it is.
Caporegime
4 Jun 2009
Mine is lovely and quiet, even compared to my MSI GE 290 which was massively undervolted.
My temps for the sapphire pulse:
Not touched anything in wattman yet.
19 Oct 2002
Right! - all installed and seems to be working fine (which is a relief - I was a bit worried about the motherboard and PSU being up to it). In terms of tweaking (and hoping not to be a numpty and stuff anything up!) - is the 'received wisdom' that I create a custom profile in Global Wattman and change the P6 and P7 states to 1100 mV and increase the power limit to +50%. Is there anything else I need to do - for example play with fan speeds etc?
6 Dec 2018
The third 8 pin connectir on the limited edition from sapphire, isnt it used only for the extra leds and if you planning to overclock it for more power ?
And they also saying it has a vapor chamber ?
21 Jul 2005
Officially least sunny location -Ronskistats
OK so I downloaded the latest drivers and installed them after a DDU cleanout in safe mode. To my dredd I got the BSOD WHEA error that must be happening to others (pci express 2 issue) as I have an older motherboard. It is a Sabertooth 990fx r2 with latest BIOS.
Good job I created that restore point!
Anyone notice workarounds to this? I fear badgering AMD about it will get nowhere, and the chance of a BIOS update coming from ASUS slim to none as it was last updated in 2016.
Man of Honour
OP
21 May 2012
Dalek flagship
Hope I can make the roll of honour? Loving my Sapphire Radeon RX VEGA 56 Pulse!
Welcome and on TROH.:)
The Roll of Honour.
Date 08/12/2018, Make Sapphire Pulse, MissJen, Link
Date 05/12/2018, Make Sapphire Pulse, Tiny Clanger, Link
Date 05/12/2018, Make PowerColor Red Dragon, Aztec2Step, Link
Date 25/11/2018, Make Sapphire Pulse, Sideeffect, Link
Date 19/11/2018, Make Sapphire Pulse, Th0nt, Link
Date 19/11/2018, Make Sapphire Pulse, Deathwish, Link
Date 19/11/2018, Make Sapphire Pulse, DragonQ, Link
Date 19/11/2018, Make Sapphire Pulse, SydDanube, Link
Date 18/11/2018, Make Sapphire Pulse, gazzaa, Link
Date 18/11/2018, Make Sapphire Pulse, linaaslt, Link
Date 17/11/2018, Make Sapphire Pulse, doodah, Link
Date 12/11/2018, Make PowerColor Red Dragon, OLDPHART, Link
Date 03/11/2018, Make PowerColor Red Dragon, scrivz69, Link
Date 03/11/2018, Make PowerColor Red Dragon, scotty63, Link
Date 05/07/2018, Make Asus Strix, Davanius, Link
Date 27/11/2017, Make Reference Air, ubersonic, Link
Date 24/11/2017, Make Reference Air, WigglesGRN, Link
Date 07/11/2017, Make Reference Air, Kei, Link
Date 04/10/2017, Make Reference Air, Illuminist, Link
Date 01/10/2017, Make Reference Air, WizardOne, Link
Date 21/09/2017, Make Reference Air, SHOGUNXSHINOBI, Link
Date 20/09/2017, Make Reference Air, Overlag, Link
Date 15/09/2017, Make Reference Air, Jazz2k, Link
Date 15/09/2017, Make Reference Air, lowdog, Link
Date 13/09/2017, Make Reference Air, Evilmethod666, Link
Date 07/09/2017, Make Reference Air, jimhaumman, Link
Date 05/09/2017, Make Reference Air, FiremanSam, Link
Date 03/09/2017, Make Reference Air, erazor51, Link
Date 03/09/2017, Make Reference Air, Angst, Link
Date 01/09/2017, Make Reference Air, solarp, Link
Date 01/09/2017, Make Reference Air, slunge, Link
Date 01/09/2017, Make Reference Air, Narrack, Link
Date 01/09/2017, Make Reference Air, Daiyus, Link
Date 31/08/2017, Make Reference Air, icey_haj, Link
Date 31/08/2017, Make Reference Air, Vince, Link
Date 31/08/2017, Make Reference Air, sideways14a, Link
Date 31/08/2017, Make Reference Air, MagicBoy, Link
Date 31/08/2017, Make Reference Air, Roob65, Link
Date 31/08/2017, Make Reference Air, sjones1404, Link
Date 29/08/2017, Make Reference Air, bells, Link
Date 29/08/2017, Make Reference Air, Sybra, Link
Date 29/08/2017, Make Reference Air, docsonic, Link
Date 29/08/2017, Make Reference Air, Disjunto, Link
Date 29/08/2017, Make Reference Air, old gamer, Link
Date 29/08/2017, Make Reference Air, FelixB, Link
Date 29/08/2017, Make Reference Air, megatron, Link
To get on the Roll of Honour all you have to do is post a pic with your user name on it of your Vega 56.
