Caporegime
- 30 Jul 2013
Funnily enough I won't be putting that on
It was always washed off as soon as I saw it anyway. No paint damage.
Is this right? "Front brakes have 90,000 miles / Rear Brakes 70,000 miles" ?
EDIT: Just seen the pics on the idrive screen, so they are correct ?
Hmm yeh I'd just say that all tyres have at least X treadHad to get a new tyre before it was fully worn due to a puncture that couldn't be repaired.
You think I shouldn't mention it?
Different tread depths on the rear tyres would put me off tbh.
I had them changed fairly recently.
I think it adjusts based on your driving style. I'm very easy on the brakes.
Two different trade people have offered me £11,000 and £11,500 for it, respectively.
New G20 3er has an ebrake like g30 5er. F30 is just old...
Is the auto gearbox in the e60 lci 535d better than the one in the lci 335d? From my research it seems the one in the lci 335d is the same as the prelci e60 auto gearbox?
It's largely the same box but it lacks the electronic shifter functionality that it has in the E60 as the E60 got the second gen model.
If you don’t brake, why not?Is this right? "Front brakes have 90,000 miles / Rear Brakes 70,000 miles" ?
E89 Z4 is a generation older and has an electronic handbrake. It always struck me as odd the 3 series was introduced without one. The X3 has one too and it's the same platform and older.
I don’t have an f10 but know someone who keeps getting this error.
Check the fuse first, its somewhere in the rear iirc.
If you turn the wheel lock to lock a few times it should recalibrate and so long as there’s no other issue it should behave itself.
I’ve asked him earlier about this and he said try disconnecting the battery for a few minutes before doing the lock to lock recalibration, if it’s still playing up then unfortunately it looks like you need further investigation.Evening, so I've located the fuse box in the boot on the right and according to the card and this link the parking assist is 8, 134 I've checked location 134 it looks fine, I've gone lock to lock a few times but the issue still persists unless I'm reading the fuse board or pictures incorrectly, can someone confirm please
