Best 140mm fans for radiator.
11 Jul 2003
Telford//west mids
When I had the old model evolv I used the stock fans and found them lacking the power to use a lot of air.
I boxed the stock fans in the x as I got a good deal on the 5 red led MLS and they push a fair bit of air on low,and I've now got the option in the summer when it gets hot I can run them faster to cope.
1 Jul 2011
Yeah, the Evolv X comes with 1200rpm variable voltage fans while PH-F140MP we can buy are 1600rpm PWM fans .. that is 25-33% more airflow/static pressure from real PH-F140MP. Considering PH-F140MP have simialr performance and costs less than 1/3rd what MLs' cost at £29.99 each against PH-F140MP 2-pack for £16.26 it's no surprise OcUK has a hard time keeping 2-pack of PH-F140MPs in stock. I'd much rather spend £8.13 than £29.99 for a fan. :D
Which MLs did you get, the 1200rpm or the 2000rpm models?
26 Nov 2009
I have the Silent Wings 3 PWM (BL067) Max 1000rpm and it seems to not be very silent at low rpm, I can hear it starting to make a quiet but low frequency noise at below 500rpm and it gets louder the faster it spins. I always thought that it was near silent until I put it into a silent case and now it's the only thing that bothers me. So I may look atthe ML140's myself.
Arctics are good though and cheap.
I have those SW3 fans like yours and mine are very quiet at 500rpm.
1 Jul 2011
Thanks for the info. Guess you are in the lucky group that MLs work/sound good for. I almost always use fans that have 300-800rpm more speed than I normally run them. Heck, I've used 2500rpm fans that never ran over 1150rpm, even during heatwave summer days at full load. Well, once in a while I would do a shock and awe and turn off all fans at full load for about 5 minutes to get temps up to about 85c, then start case and cooler fans back up and they would spin up to 2500rpm :eek: for maybe a minute before starting to slow down and be back to normal 1050-1100rpm in a few minutes. :D All of my systems go from idle to full load temp almost instantly .. take less than a minute to be within a couple degrees of maximum temp, and in less than 2-3 minutes temp graph line is flat at full load temp until dropping back to within a couple degrees of idle temps in same couple of minutes.
rn2
rn2
13 Mar 2017
England
I just bought another SL3, now I have two 140mm SL3's on my GPU lol. They don't go above MSI fan speed of 16-17% at 100% GPU usage for 30 minutes (45% MSI fan speed is 100% fan speed of 1000rpm).
So running the games I play it should never need to go above these speeds and now my computer is inaudable over my speakers.
I will get water cooling in the future so I dont have to mess around with a lot of fans. I've spent £150 on getting it quiet over the last year or so (different fans etc) should have just water cooled it. One day I may live somewhere where I can shut the thing outside the room.
Not sure why I buy exactly the sane fans and some hum and some are silent. Ive returned about 5.
19 Mar 2014
My Evolv X fan config is 3 x NF-F12 iPPC 2000 PWM that came with the Ryujin 360 mounted as a top radiator exhaust and I added a further 3 of the same model as from intake with a NF-A14 iPPC 2000 PWM as rear exhaust.
Very happy with noise and temperatures.
1 Sep 2010
Bristol, South West
Sorry to bump this old thread, maybe someone is watching, but I have 2 x phanteks ph-f140mp's which I bought in china, as many say they are awesome, and were 5 quid in china, and they only seem to spin to 1350rpm. They do not have any writing on the sticker, just the phanteks shiny silver name sticker. I heard someone say before that the ones WITHOUT the naming on are the cheaper ones they put inside their pc cases, do you think I have those?
Also, IIRC, the packaging had written on them ph-f140mp @ 1600 +/- 350... What does that +/- mean? clearly its not they can spin over or above that 1600rpm number.
I have to say they are pretty silent even at 1350rpm, silent up to about 1200. I can heat the air but my nh-c14s is still cooking @ 85c whilst gaming... only 1 on there atm, in pull.
1 Sep 2010
Bristol, South West
Is this the fan?
Do you know what the +/- means? I see that on a lot of fans and i swear it was on these as well, but dont have the box now. I was hoping for a 1600pwm fan. dont mind a little noise, as usually blast the volume from a hi-fi when gaming anyway :D
I guess the fact the spec sheets @ 1600rpm +/- 250 and my max rpm totalling 1350 isnt a coincidence
26 Nov 2009
You said +/- 350 in your first post and now +/-250.
1 Sep 2010
Bristol, South West
1600-250=1350
1600+250= 1850
So the fan can run between 1350-1850rpm.
UUmmmm Ok... My maths isn't that bad, but thanks... I guess? I'm asking what does the 250+/- symbol mean that you seen on fan spec sheets. Have you noticed it before? Theres a number next to the rpm with + symbol above an underscore.
Every other fan I have owned goes up to the stated number.
26 Nov 2009
+/- means allow for deviation from the quoted rpm.
1 Sep 2010
Bristol, South West
You're sure? I thought that but every other fan I've ever owned has a deviation of like 1-50rpm, I'd say 100 absolute max... Isn't 250 a little excessive and like said, a coincidence? It's an exact number. Wow thats crappy... So If I want 1600 rpm in future I should buy a 2000?
