The RX Vega 56 Owners Thread
23 Jun 2004
Blackburn
Edit: I found my old psu box with all the accessories and there was a spear gpu power cable, i plugged one end into PSU, and other one into GPU as you guys showed, but I get the same results :/
My PSU is EVGA 550GS supernova
And after since the screen is black, it automatically goes back to HDMI
Does your GPU display an image at POST? Which drivers are you using?
With my V56 if I use any drivers later that 18.12.1.1 I get a black screen after the Windows logo when I PC boots up. I assume thats when the drivers load.
18.12.1.1 and all earlier drivers are perfectly fine
31 Dec 2011
I find wattman has an issue with keeping my saved settings, maybe yours are messed up? Tried a full driver uninstall, clean install etc?
Do you run afterburner as well? I had the exact same issue and it was the "Erase autosaved startup settings" under the general tab of afterburner that was causing it.
its been fine since.
7 Aug 2009
London
Cheers mate, but don't user afterburner. The only other piece of software I had been using was clockblocker but have since disabled that, problem still persists so may do a big reinstall myself.
31 Dec 2011
Cool, the other thing I have installed is OverDriveNTool which seems to help with getting wattman to keep its settings.
14 Nov 2018
So I tried another game with my pulse. Tomb Raider. I see this white flicker of some textures (in tomb raider it was actually smoke that was turning white for a split second every so often), even on the balanced clock. I noticed it happens more regularly when fans spin up. My coil whine also got quite bad. Is this another GPU I need to RMA?
GPU-Z reports 182W of draw on the balanced profile.
28 Nov 2005
Wrde
Thought I could hold out until later in the year but have cracked and gone for the pulse. I'll have to take a closer look at the rest of this thread but is there a general consensus on the undervolt settings or is it card dependent?
16 May 2007
It depends on the card. The settings I use are fairly tame as I wanted stability with reasonable lower temps. With tweaking better performance is available.
Voltage p6 / p7 1100
Gpu P6/p7 1590
Hbm 875
Fan speed 800 to 3000
Target temp 68c
Power +25
In most games unless hitting an fps cap the Gpu is heavily utilised.
28 Nov 2005
Wrde
Voltage 1100
P6/p7 1590
Hbm 875
Target temp 68c
Power +25
Great thanks for that, I'll hopefully get around to installing it over the weekend so will give these a try.
6 Dec 2008
York
my card is dead, turned on my pc this morning to massive icons on the screen. showing no card in device manager,gpu-z, furmark or heaven. Was working fine last night as I played Farcry 5 for a few hours. any ideas guys as it's a pretty new card and I am gutted if it's dead.I have checked and re seated the card and the power, all good. Card is lit up but nothing else. PSU is an XFX 750w so plenty of power and 2 leads to the card.
7 Aug 2009
London
You don't have any IGP enabled by mistake? Check the bios and make sure IGP is disabled, I made that mistake and my vega would occasionally concede to the IGP lol and scare me. I fixed by disabling it in the BIOS
3 Feb 2015
Hey guys, I haven't read the whole thread so sorry if this has already been addressed but I've just had a Sapphire 56 Pulse and i thought I'd report my findings..
I use Pcars2 to do the tests, watching replays with different settings etc.
This card can do QHD@75 nicely on stock with the game settings maxed out and using cockpit view. Replays take a bit of a hit and can drop down as low as 35fps (Rainstorm, full grid off the start line) but with freesync it's not so bad, mostly they run around 50-70fps though
Overclocked it eats 1440p@75hz (Frame limiter set to 74fps) including replays and even can do QUHD@60 whilst racing (Cockpit view) but is console like in it's 30fps odd replays.
Overall I'm massively impressed and it easily does what i brought it to do, which is 1440p@75 (With Ryzen2600)
One thing i noticed though is the HBM temps.. If i leave it at 950Mv, overclocked, GPUZ reads 99deg! but if i lower it to 900Mv it stays below 70deg but will still perform a stable 950mhz.
So i suppose these stock voltage settings are wrong or something, which is odd but all in all I'm well chuffed with my upgrade.
If anyone asks can Vega64 do 4K@60hz, based on my performance results for V56, I'd say yes, just about.
15 Oct 2018
Going by what I've vaguely read elsewhere, the Vega series needs a bit of care and attention (undervolting, possibly even a BIOS flash) to achieve its highest performance in frame rates / thermal performance. I'd suggest you look into it.
3 Feb 2015
I've got an RMA because of the excessive HBM temps and coil whine so doubt i'll be doing that. Might still go green yet, i'll see. Do like the render quality of this vega card though...
