8700k - did i just win the lottery?
24 Aug 2014
I’d like to see some completed scores with that clock showing ;) It’s probably still ‘good’ as that’s what the 8086 are but it doesn’t really give a true picture to say simply delid and magic happens.
Old benchmarks but there you go ...
Cinebench R15 and old Win7 without SP :) 5.4GHz score 1786cb
Unigine heaven 4 - score 6890
https://forums.overclockers.co.uk/threads/unigine-heaven-4-benchmark.18487976/page-206#post-28330032
Firestrike Standard Bench - score 36938
https://forums.overclockers.co.uk/threads/firestrike-standard-bench-thread.18665940/
https://www.3dmark.com/3dm/29503203?
Firestrike Extreme - score 25008
https://forums.overclockers.co.uk/t...-extreme-bench.18487344/page-62#post-27387418
https://www.3dmark.com/fs/16736727
Firestrike Ultra 4K - score 14033
https://forums.overclockers.co.uk/threads/firestrike-ultra-4k-benchmark.18629665/
https://www.3dmark.com/3dm/29503275?
Corsair 900D project still wip ;)
My custom AIO & Fluid ... EK Phoenix 6 fans sandwith and TOP OC mobo - Rog Maximus X APEX :rolleyes:
btw. I know what I'm doing ... thanks for advice guys :)
OP
14 Nov 2013
Ok i bumped up the cache to 52 and upped the voltage to 4.5v but i am pretty much matching your CPU score. I also looked at older much lower clocks and theyre much lower scoring - so i dont think its a stability issue? What RAM are you running? I have 3000mhz @ 3200mhz.
We have the same boards so interested to know what your other settings are?
Ive stressed this in real bench and its fine.
https://www.3dmark.com/spy/5845568
29 Oct 2009
The difference is ram probably, ran it again at 3200 vs 4000 and got this
https://www.3dmark.com/compare/spy/5846754/spy/5846354
27 Feb 2015
I dont understand why people pump cache up, I did a lot of testing and it improved nothing, not even benchmarks. After a bit of research I discovered it only really helps if you have extremely fast ram. Like quad channel ram.
Also is that 1.4v going to be a 24/7 setup? Is on the high side for that voltage in my opinion.
