Manchester airport tunnels, nice, still got no idea how these don't have averaging speed cameras in, especially after the slew of high speed footballer crashes.
Well lets hope they stay camera less for now.
As I said from passenger seat it felt strong and though its probably not but it feels quicker than the GTR, just more thrilling even from passenger seat, more noise, closer to the floor etc.
I got to do an experience day where I drove a GTR and a Gallardo, sadly they made me short shift, the graph confirms my suspicion that I only experienced half of what the Lambo is capable of, the GTR was probably a little better feeling in the low rpm due to the turbo, not sure it really is like that, just how it felt.
Last time I did an experience day honestly a hotlap in Assetto Corsa would be more of an experience hah![]()
That's not tracking, that's alignment. You had that done with new tyres on too? Local race alignment centre to me suggests alignment is done with old tyres on before replacing with fresh rubber
I understand that approach, but I think its flawed. Aligning with the old tyres, which have been used and covered a good distance, aid the operator to visually see what and how the car has behaved and can tweak those settings accordingly. Putting fresh rubber on and driving next door to the alignment centre isn't going to give the full picture and could mask hidden issues. I recall a a 911 having alignment done which had a shifted subframe from a heavy front impact which had gone unnoticed. Alignment machine said it was pretty much fine (from a previous alignment), tyres (and the way it drove) suggested not.Should always be set with the rubber you intend to race on, albeit scrubbed in but they were scrubbed in as he'd already put around 500 miles on them.![]()
An alignment and a full geo are different to be fair. Done right it needs corner weighting, ride height, camber and all sorts of things and is also personal and built over time. When you go to someone who is highly experienced, such as Chris Franklin you will get a well set up car that will reflect what you ask for. Good front end, good steering feel, sharpness, road/track bias etc. Both are good to have, the geo at the start, tweaked perhaps to get it where you want and then some alignment to ensure road use has not knocked it out, but typically they should be at the same place. I had my R8 done at Audi, it was better as it was out but still know a full Centre mavity or other reputable setter up of cars could make the different.
I had my GT3 with a vicious track set up which on the road was really hard work, on track epic. @Gibbo drove it with that set up but few weeks after that I had it softened off as it was too hard for road and it was better, if still challenging. A set up is a personal thing, but you need a starting point and to work from that and ensuring it is aligned after new tyres is the right starting point. Now how it wears those tyres and as you get to learn the car will provide the best insights into how it performs and handles and what you might want to do next.
I love a really sharp nose for example, with understeer I struggle, with oversteer I am fine, but my preference is neutral but with a really aggressive front I can push in hard and late. Others prefer a totally different set up and for road use I just like a nicely damped and camber/bump resistant drive.
Most cars limit what you can do with a suspension set up, but something proper, like a GT3, means you have really go to town on them. Transforms cars done well as you will appreciate.
Not an expert to be honest but with active damping and 4 wheels steer it will be more complex that my 996.Yep, does the 991.1 and 991.2 GT3 come with full adjustable suspension do you know, like anti-roll bars, dampers etc. from factory?
Just asking so that if I did go GT3 it can be fully adjusted from factory?
@NathWraith I was sure You had enough adventures with Supra or Two
Lambo is lambo End of. It's not fastest its not best handling.
But looks Epic in Any colour better than some Ferrari or Porshe.
